brokeframe - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-05-2002, 09:20 PM
brokeframe
I have an 86 cj7. I snapped the frame. I was hoping for all sugestions on what I should do? How long will the frame hold up if welded?what is the most economical frame to get?ANYTHING whould help!
post #2 of (permalink) Old 01-05-2002, 09:22 PM
Re: brokeframe
you need to fill out your profile. i know someone that has a good frame for not much money. where are you at?
J ust
E mpty
E very
P ocket
yjdave is offline
post #3 of (permalink) Old 01-05-2002, 09:28 PM
Re: brokeframe
depending on where its broke, and how badly, it can most probably be welded, and a plate or 2 added ( sandwiched) to make it last forever.
OzarkJeep
too small to be seen, and too big to control, and treated like a walking bomb...
ozarkjeep is offline
post #4 of (permalink) Old 01-05-2002, 11:24 PM
Re: brokeframe
agree with ozark, weld 'er up and add some plates and u should be good to go. Just be careful that the frame doesn't change length when it's welded. This is especially important if it's broken over the spring between the shackles; this would cause that corner to be higher. Also be careful if the mend is between the axles; a shortening here will pull the axles off center causing the Jeep to pull on the road, excessive u-joint wear, excessive strain on the axles, and excessive tire wear. Basically, just be careful with this mend because it can be screwed up; I've seen it. The risk of this increases if the frame is rusted or in otherwise bad shape; if this is the case, look for another frame.
post #5 of (permalink) Old 01-06-2002, 09:54 AM
Re: brokeframe
If you're looking to make this as easy as possible MORE makes some frame plates that are already cut to fit, holes and all.
Brad
ORC Land Use Editor
and
