DAMN WHISTLING - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-04-2002, 07:59 PM
DAMN WHISTLING
ok ok ok, I've heard it all. Vac leak, intake manifold bolts loose, ect. But the fact remains that my 91 YJ, just f*#$ing whistles no matter how tight anything is. the whistling is definetly coming from down the air tub somewhere and i can hear it beacause i have a cone filter (thanks rusty) on the end of it. I think that its a problem with the engineering of the intake itself because it doesnt occure unless I have my foot on the gas a little. I stop it, it stops. I let off the gas it stops. If anyone has any idea on how to get rid of it, please lemmie know.
post #2 of (permalink) Old 01-04-2002, 08:10 PM
Re: DAMN WHISTLING
Easiest solution is to remove the cone filter and replace it with the stock air box. That whistle is the reason the factory doesn't use high flow filter. You hit the gas and the engine sucks in air. More air goes through the cone filter and the whistle begins.
'88 Sahara, 4.2 that runs thanx to every Cheap trick on this board. The rest is getting there![img]/wwwthreads_images/icons/blush.gif[/img]
post #3 of (permalink) Old 01-04-2002, 08:27 PM
Caver Dave's Avatar
Re: DAMN WHISTLING
I rode with a guy that had a "rocket tube"(?) on a YJ. It whistled like a turbo or something.
I think all you'd have to do is breakup the air a little with a bolt/strap thru the tube. Well, maybe it'd work....
Caver Dave
'72 Commando
Oo=====oO
Caver Dave is offline
post #4 of (permalink) Old 01-04-2002, 09:11 PM
Re: DAMN WHISTLING
yeah i know the airbox will fix it...but i dont want to lose any power, hehe. I have a powerful YJ. I have the filter, high flow cat, flowmaster a low temp stat, and a stage 2 jet chip. i burn all the rice rockets. I did it all so i could still have power when i put them 31's on
post #5 of (permalink) Old 01-04-2002, 09:51 PM
Re: DAMN WHISTLING
I have the very same problem on my 83 CJ7 258 with standard air box. Damndest thing. I gave up trying to find it after replacing every friggin hose under the hood. I'm not buying the fact that your cone filter is the culprit. Good luck...
post #6 of (permalink) Old 01-04-2002, 11:03 PM
Re: DAMN WHISTLING
If you can bear it leave it alone.. mine does the same thing.
It comes from the air being spun so fast it whistles. I put a body spacer on and it whistles now. they say that it cools the air, and carries it into the combustion chamber better.. Something like that, but they people say it aint bad.
JR
The road is calling, Ignore it!!
There is life after asphalt.
post #7 of (permalink) Old 01-05-2002, 11:55 AM
Frank360
Re: DAMN WHISTLING
Mine ol' 360 does the same thing, but I can't remember if it only started after I put the K&N filter on there... but I feel reassured that it isn't a real problem, like my temperature gauge that just quit !!
post #8 of (permalink) Old 01-05-2002, 12:03 PM
Re: DAMN WHISTLING
I agree that it comes from air into the airtake as well. I recently replaced my stock airbox with some pvc and a cone filter. I got the filter up higher than the stock airbox so it would be less likely to suck in water and I figured an open air element might help free up some horseys over the stock restrictive airbox. I noticed the whistle right after I did it. It doesn't particularly bother me though cause my exhaust is so loud, at higher RPMs it just gets drowned out.
Jay
95 Wrangler Rio Grande...She's gettin there - I'm all about the 4 cyls
http://www.geocities.com/heavycream
