OK Jeff, I'll start. CTM info - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-02-2002, 05:48 PM
cj7jeep
OK Jeff, I\'ll start. CTM info
From what i remember, you run Warn alloy axles with CTM joints. I think i remember reading the axles use full circle clips, which helps out alot. I already have alot of $ in my d44, and don't even come close to the level of 4wheel'n you do. What do you think, will a built d44 survive with 40" tires and a Chevy v8 in the mud and sand. Sorry about butting on your earlier post with questions about CTM's.
post #2 of (permalink) Old 01-02-2002, 06:06 PM
Re: OK Jeff, I\'ll start. CTM info
will the CTM joints just mangle stock D44 shafts? instead of snapping?
OzarkJeep
too small to be seen, and too big to control, and treated like a walking bomb...
ozarkjeep is offline
post #3 of (permalink) Old 01-02-2002, 06:16 PM
I think you have to use aftermarket shafts as the CTM joints use full circle clips, or have your stock shafts machined to use the full circle clips
CTM web site: http://www.ctmracing.com/about.shtml
Tom
post #4 of (permalink) Old 01-02-2002, 06:16 PM
I run the Warn High strength axle shafts.
Jack has not had any shaft failures with the Warns, but he has pictures of a couple of failures with Mosers. Because Warn makes their own shafts, they can roll the splines then heat treat everything at once. A company like Moser has the shafts made for them, then they cut and spline as needed, which does not affectively treat the entire shaft as thoroughly, (or so I am told).
In any case, the thing that I know for sure, is that the Warns have held up for me without failure. Drivetrain Direct sells them(complete sets of long and short side inners and outers) with a no questions asked lifetime warranty, for $549, no tax, and free shipping(the even come with new spicer joints, that you can give to your friends, cause you wont need them).
The Joints come with a lifetime warranty, and will be about $300 for a set. They come with their own full circle clips.
They would be a waste on stock axle shafts.
The joints and shafts will easily handle the 40" tires, but you will be putting that same load on the ring and pinion, and the locker. So far my ARB is holding up well. I have grenaded a Warn locking hub assembly, so that is at least some excample of the loads being generated.
I would suggest a full carrier locker assembly like a Detroit, ARB, or OX(if it turns out to be as strong as supposed to be).
Jeff
89 YJ
(sensibly altered for occasional off road use)
Vision without Action, is a Daydream. Action without Vision is a Nightmare.
H8monday is offline
post #5 of (permalink) Old 01-03-2002, 08:11 PM
thats no sweat, I had read about doing that to my stockshafts anyway.
Im just curious what aftermarket shafts for a dana 44 cost, and will the stronger Ujoints make the most likely expensive shafts the weak link, or will it be the hub?
IM pretty cheap
OzarkJeep
post #6 of (permalink) Old 01-03-2002, 08:24 PM
OZ,
I can really only tell you what I know for sure.
You would be the test dummy, using anything else.
I do know that Moser high strength shafts have failed repeatedly, so I can only imagine what stock shafts would do.
I did explode a Warn premium locking hub this last weekend. But as you know, I use the Warn High Strength axle shafts and stubs.
Jeff
89 YJ
H8monday is offline
post #7 of (permalink) Old 01-03-2002, 08:28 PM
yeah Jeff,
I didnt see your above post when I asked that question.
its not my gig, cool and all.
and I wish I could stuff like that, but $549+300, thats enough money to finishf my rig, or 3 times what I have in my drivetrain.
heh thanks for the info!
Ill just drive vicariously thru you
OzarkJeep
post #8 of (permalink) Old 01-08-2002, 06:28 PM
I Do This For The Glory
JEEPN's Avatar
Jeff, have you had a ring or pinion gear let go?
JEEPN
Winter Harbor, Maine
'88.5 Slamurai, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #9 of (permalink) Old 01-08-2002, 06:40 PM
Ive had 2 D30 R&P failures but nothing on the D44. The U joints would always let go in the past, and I had a freind with a Differential shop completely go through my D44 before the CalRocs competition, when the CTMs were installed.
Jeff
89 YJ
H8monday is offline
post #10 of (permalink) Old 01-08-2002, 09:33 PM
Anybody care to venture a bet on what is the next Weakest Link?
There's always a fuse in any system, the trick is finding it before it blows up in your face... [img]/wwwthreads_images/icons/shocked.gif[/img]
bluseman2a is offline
