nerf bar cover gone - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-31-2001, 01:21 AM Thread Starter
nerf bar cover gone
I've included a link to a picture of my nerf bar. the plastic step cover was removed by vandals. both covers are gone and I don't know what brand they are. I think it's guanine steel. the bars are welded in and I need to get them covered up. Any body have any ideas?
http://members.aol.com/_ht_a/gouldvo...ep/nerfbar.jpg
1989 jeep YJ,4.2L,5spd
room a zoom zoom!!!!!!!!
http://hometown.aol.com/gouldvolts/jeep/jeep.html
speed_buggy is offline
post #2 of (permalink) Old 12-31-2001, 02:20 AM
Re: nerf bar cover gone
Were I to make the repair I would:
a. Buy some 16 ga aluminum diamond plate.
b. Cut two pieces the width of the tube (make it longer than the opening as you need to make up for the curveature of the ends...).
c. Cut a four pieces of 2"X4" three inches long.
d. Center the cut aluminum over the opening in the nerf bar.
e. Using a large vice grip pliers, compress the aluminum down to the tube and lock the pliers.
f. Using the wooden block made in step "C" and a hammer, deform the aluminum to fit the curve of the tube opening.
g. Use a "C" clamp to hold the ends down into the nerf bar.
h. Using a permenant marker, trace the outline on the underside excess aluminum plate.
i. Remove the clamps and the plate.
j. If done right, the plate should conform to the opening in the nerf bar.
k. Measure and drill holes in the plate to affix the plate to the nerf bar.
l. Cut the aluminum plate to match the outline drawn in step "h".
Now if you want to do a better job of this...I'd weld a tab on the top of the nerf bar openings, and another mid way accross the opening and drill the tabs for screws. Then drill matching holes in the aluminum plate.
This addition will help to draw the ends of the plate to the tube and secure it in place.
Before screwing the plate in place apply a 1/4" bead or Silicon (RTV, sealant, etc.) to the nerf bar. As the plate is drawn to the nerf bar with the screws the sealant will spread and seal the seam. After the sealant cures trim the excess and you're done.
See... easy as pie!
post #3 of (permalink) Old 12-31-2001, 03:05 AM
i like leve's idea or just take the whole things off.
high5
it's one ton o' fun!
post #4 of (permalink) Old 12-31-2001, 04:52 AM Thread Starter
thanks for the recommendation.
I'm thinking about using Diamond Plate step pads from genuine steel.
post #5 of (permalink) Old 12-31-2001, 01:32 PM
I'd just say get rid of them,it isn't that hard to grind them off and then sell them on e-bay, replace them w/ some angle iron rocker skids and make a removable step.
BarrelRoll
97 TJ
Wheel it or drive a minny van
Jeeper99xj is offline
