weber adapter - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-31-2001, 12:19 AM
MaineJeep
weber adapter
I'm looking for a weber 32/36 adapter plate and linkage for my 87 258. I've got the carb only, anyone have any of this stuff?
post #2 of (permalink) Old 12-31-2001, 01:10 AM
Re: weber adapter
There is no adapter necessary. It bolts directly to the stock manifold if I remember correctly. I run mine directly on top of my Clifford intake.
The only thing you MIGHT need is the plate that has a port for your PCV vent, but any manifold vacuum will do just as well. Mine runs off a T on the PB booster vacuum feed.
On the linkage, I have not seen a good after-market solution to this. Weber has one for like $80, but it's pretty crappy. When I put mine in, we took a piece of flat stock and bent it into a Z shape, hung it off the manifold, and it works just fine. I would be prepared to fab yours.
bluseman2a is offline
post #3 of (permalink) Old 12-31-2001, 06:14 AM
MaineJeep
Re: weber adapter
Do you have a picture of that linkage setup that you could post?
post #4 of (permalink) Old 12-31-2001, 10:03 AM
Sully
Re: weber adapter
I would double check about the carb bolting directly to the stock manifold for a 258. I know I used a pair of adapter plates to change the Carter BBD to the Weber 32/36 on my '84. The bolt pattern looks different to me...
I can check it tonight.
Sully '84 CJ7Laredo 258/HEI/Weber
