the noise is back!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-30-2001, 08:14 PM
the noise is back!!
ok, so now my jeep is running fine, i found the faulty wire. BUT, my belts are squealing once again just like last winter. it finally got cold down here in mississippi, and they squeal again. ive changed the belts, i even went as far as trying that BS belt dressing but nothing works. this only happens when its cold, and it doesnt stop once the jeep warms up. can anyone help?
War Eagle
post #2 of (permalink) Old 12-30-2001, 08:24 PM
Official Historian
WILL's Avatar
Re: the noise is back!!
It seems like LEVE had a good solution to this last year but I don't remember what it was.
WILL is offline
post #3 of (permalink) Old 12-30-2001, 08:29 PM
LEVE, help me out!!
War Eagle
post #4 of (permalink) Old 12-30-2001, 08:35 PM
Have you tried Ivory Bar soap ? Works on my kids car for about a month , then redo .
<font color=black>Jeff [img]/wwwthreads_images/icons/cool.gif[/img] </font color=black>
Jeepzilla is offline
post #5 of (permalink) Old 12-30-2001, 08:40 PM
Caver Dave's Avatar
Which belt is squealing? In my case, the belt retreived from "the zone", is too narrow for the sheave on my alternator. The tight bend around the pulley, coupled with the belt riding against the bottom edge (instead of the sides)makes it squeal like mad for several minutes when cold. I'm going for a little visit tomorrow and grab a wider belt of the same length.
Caver Dave
'72 Commando
(Now "Moss-less" & looking for a name)
Caver Dave is offline
post #6 of (permalink) Old 12-30-2001, 09:32 PM
Belt squeel is normally caused by the pulley moving faster than the belt. On cold days the belt is not pliable and can slip and the noise starts. So, it's important to look at the belt for any damage at all and make sure it's aligned and tensioned correctly.
Belts do glaze. When the belt's cold and flying around the pulley at a bizillion miles an hour it will squeel as the belt can't quite keep up with the pulley.... which adds to more glazing. As the friction heats the belt it softens, stretches a bit, and the squeel goes away... like when you get sick and tired of the squeel and "goose" the engine and like magic, silence occurs. You can brake down glase with a little sandpaper applied to the underside of the belt as it's moving, but bear in mind... it's your fingers... count them when you're done.
Belt dressing is now a spray, not a compound stick. I've never found it to help a great deal except to remove oil that's found it's way to the pulley. I don't think you can buy the old stick stuff any more for liability reasons... and the spray just ain't as good as the stick. It tends to fly off a few seconds after it's applied. I would not trust it exeept as a degreaser.
If the tension and the belt are in good shape, about the only thing left is the pulleys. Check to make sure the pulleys are aligned properly with one anohter. Look at the pulleys to see if the are worn and could capture a belt. A pulley can be "dished" and as the "V" of the pulley widens at the top it lets the belt slide furhter down the groove untill the pulley caputers the belt. If the belt is captured it tends to be pinched, halts, and glazes while the pulley turns. The result is a squeeling belt.
There is also a load factor that's difficult to determine. The surface of the belt and pulley can only provide so-much friction/grab and if the load of, say an alternator, is too high then the belt may also suffer and glaze over. This is a rarity, but does happen and should be considered.
Barring that, then I'd bet the problem is the cold causing the problems. Try a little talc applied to the uderside of the belt. I'm sure others will chime in with a fix as well.
post #7 of (permalink) Old 12-30-2001, 09:34 PM
both ideas sound good, soap might make them slip more though. but as far as the wider belt, how do i go about getting a belt that is wider but still the same length? any certain make or model that would have the same length but wider belt than a 304?
War Eagle
post #8 of (permalink) Old 12-30-2001, 09:49 PM
Andy, do a search on "baking soda" and look at Extinctjeep's post. Sounds strange but worth looking at!
Greg
CJ7GREG is offline
post #9 of (permalink) Old 12-30-2001, 09:55 PM
I had to replace my crank pulley because it was worn out and the belt was now touching the bottom of the V. That meant that no matter how much I tightened the belt (hard on the bearings!) the belt had not traction, as it's the sides of the belt that make proper contact. Anyhows, I swapped the drive pulley from a spare motor and never had a problem since. It was always worse in the cold or if snow got sucked in thru the radiator.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #10 of (permalink) Old 12-31-2001, 03:39 AM
what all is needed to remove a pulley? im sure theres some type of puller, just checkin
War Eagle
