electric fan conversion. Doners? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-30-2001, 03:35 PM Thread Starter
Hey all,
Well I have been mulling it over for about a week now, and I came to the a few conclusions: 1)I want to go to electric fan from a stock clutch engine driven fan. 2)I don't want to pay something like $350 from a jeep catalog for a dual fan setup(eventho it looks complete and exactly what I want, I just can justify it) 3)I have no clue of what car to pull an electric fan out of.
I understand the wiring, adding a temp switch to turn it on, and an overide switch to turn it off in water.
this is for an '85 CJ-7 with a 258cid with a serpintine belt.
thank for the list.
surveyboy
http://www.csupomona.edu/~sdmiller1/jeep.htm
surveyboy is offline
post #2 of (permalink) Old 12-30-2001, 04:26 PM
dave's Avatar
Re: electric fan conversion. Doners?
My first choice for an electric fan would be from a late model Ford T-Bird (early to late 90's). I would think that a salvage yard would be an affordable source.
dave
dave is offline
post #3 of (permalink) Old 12-30-2001, 08:33 PM
i run a dual fan setup from SPAL and it works great! it has dual 11" fans and the shroud fits perfectly on a cj radiator. i had all sorts of cooling prob's before i went to these fans and like i said they WORK! they are $200
high5
it's one ton o' fun!
post #4 of (permalink) Old 12-30-2001, 09:27 PM
There was a discussion of this a while back on the BBS. A couple of people said the best one was from a Ford Crown Victoria. The use the Ford Crown Vic for police cars and elec fan works very well.
85 CJ7,Chevy LT-1,700R4,NP208,4 1/2 lift,33's
77 Blazer,350 Cowl Induction,TH350,NP203 8", 33's
post #5 of (permalink) Old 12-30-2001, 11:28 PM
86CJ7's Avatar
I noticed you live in CA. If you have Air Conditioning make sure that the fan runs when your AC is on.
86CJ7 is offline
post #6 of (permalink) Old 12-31-2001, 12:01 AM
check out a Ford Contour 2.5 V6. The dual fan shroud assy has thin fan mtrs and it fits exactly the width of a CJ radiator. You may have to trim off about 1 inch or so of the bottom of the shroud with a band saw. I had one on my CJ for a while and it pulls a bunch of air, but it also pulls a lot of amps. my alt. could not keep up. I think I measured 40 amps. be careful, I melted a relay... I re-wired it with one relay for each fan.
post #7 of (permalink) Old 12-31-2001, 12:19 AM Thread Starter
Well, I found a pair of 14" fans with the following specs:
FHP-34114 Ultra Thin Line 12V Electric Fan
dia width cfm weight amps
14 3.18 1769 3lbs 10.2
I know that 14 is to wide to use duals, but I got a great price on the pair and I am going to use the second as a backup in the spare parts bin.
post #8 of (permalink) Old 12-31-2001, 12:25 AM
Pooh-Bah
pbmcauliffe's Avatar
I had a 14" PermaCool (2950cfm) on mine in place of the stock unit. It kept the 304 cool on a normal day, but long slow crawling the temp crept up. I just added another one as a pusher behind the grill to keep it in check when summer comes around.
<font color=purple>pbm</font color=purple>
<font color=red>There is a difference between being Educated and Intelligent!</font color=red>
pbmcauliffe is offline
post #9 of (permalink) Old 12-31-2001, 03:41 PM
Flex-a-lite makes a special dual 12" fan just for CJ-7's. Check their webpage for the part number. It was a special order from summit racing for $300. Turns out it's the same fan setup as their low profile part number FLX-210 ($205) from summit racing with a couple of sheetmetal brackets and four small cutouts for bolt head clearance. So basically it's a 100 bucks for the two little brackets. If I did it over again, I'd just go for the $205 fan and mount it myself. It's really powerful and keep my 5.0HO cool in traffic and it's not very loud. I recommend it.
zimm is offline
post #10 of (permalink) Old 12-31-2001, 04:06 PM
GeeAea's Avatar
Can't you do what pbm did and reverse the second as a pusher (you should be able to reverse the polarity)?
GeeAea
Now that I've quit smoking my doctor was pleased to inform me that I'll die in much better health!!!
GeeAea is offline
