SOA welding +geometry
I've read quite a few posts on here about the whole SOA thing, but I'm curious about what type of welding rod you guys use to weld the steering knuckles back on with (7018?).
Also, how do you figure out what angle to set the pinion at?I assume you would need that angle before setting the caster on the knuckles?
I have a chance to buy a full size Cherokee and I have an old set of '75 Suburban axles laying in the garage, thought I might try to do an SOA and put all the '79 Cherokee drive train in it as well(360,4speed). Hoping to go with 36" tires,so maybe the 2" lift I have now, these springs would work?
Thanks for any response
Bob
