extended brake lines - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-2001, 07:25 PM
Found post about using the brake lines on a 80 C30 to get 6 extra inches on CJ 7. Need suggestions on what to do for the rear lines?
82 CJ 7
Looking for cheap mods. $100 for brake lines is crazy.
post #2 of (permalink) Old 12-28-2001, 07:32 PM
jeepgod's Avatar
Re: extended brake lines
mmm... i have the part number at home.. jeepn knows it... you could do a search on him.. and look back awhile... year ago.. i know he has put it out several times..
http://www.jeepgod.net
jeepgod is offline
post #3 of (permalink) Old 12-28-2001, 07:47 PM
There serveral posts. Now that I read more the C30 may be to long. The posts were I found the most info never were completed. I got part numbers 36537 for rear and 36931 38286 for front and 31668 front with durms. I have disk front brakes does this make a diff in the brake line? Do any of these numbers sound right. Like I said the thread had a bunch of numbers but no one was sure.
post #4 of (permalink) Old 12-28-2001, 11:32 PM
I Do This For The Glory
JEEPN's Avatar
For the rear you want NAPA #36537, it's a direct bolt on and over 7" longer than stock.
The front brake lines were the same from '77-'81 and from '82-'86. I have the ludicriously long ones (NAPA #38286), over 20" longer than stock, so you probably don't want those. I cut the hard line back a bunch and coil them around the shock in a loop. I had to drill out the centers though, as the banjo bolt didn't fit perfectly.
I have no idea as to what the lines go to, just the part numbers. It took me and another guy over 2 hours to find the longer lines with the correct ends on them.
JEEPN
Winter Harbor, Maine
'88.5 Slamurai, 7" Lift, Locked, Swamped, Rolled, and just generally broken in right!
JEEPN is offline
post #5 of (permalink) Old 12-29-2001, 12:12 AM
nxcj
follow JEEPN's line. I simply went to NAPA, pulled out the "brake line book" and hand picke what I needed. I don't know the numbers but I ended up with 8" over stock rear and 32" fronts. The fronts are actually two line spliced together. High $$ but I'll never run out of length. I had to drill the banjo out as well for my Chevy brakes (Dana 44).....
p.s. : IMO.. stainless lines will not hold up to much yanking on them
post #6 of (permalink) Old 12-29-2001, 01:04 AM
jamgood96's Avatar
How do you know if you need to drill out your banjo bolt? I got the goodrich lines from 4wd for a YJ and they seemed to bolt right up to my Chevy brake parts.
jamgood96 is offline
post #7 of (permalink) Old 12-29-2001, 08:56 AM
JEEPN's Avatar
Well, in my case the Banjo bolt wounldn't fit through the brake line, so it was obvious. You want some play, but not a lot, so the fluid can transfer between the two easily. If it's too tight, the brakes will work, but stopping will be harder, i.e: you'll press down on the pedal hard but the brakes own't grab easily, then they won't return (release) fast either and will drag. It'll be obvious.
JEEPN
JEEPN is offline
post #8 of (permalink) Old 12-29-2001, 01:31 PM
jeepgod's Avatar
79 and older waggy calipers have a larger banjo bolt.. vs the 80 and newer waggies.. they are the same size as the jeeps.. yj/cj... i had to drill mine.. its just brass.. so no biggie...
jeepgod is offline
