Conferr Axle Truss on top of AMC 20 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-2001, 03:00 PM
thejunker
I want to strengthen up my AMC 20 rear (83 CJ Stock rear axle w/ 1 piece, Detroit, 4.56 gears), and was looking at the con-ferr truss (see pic), but I really do not want to lose the ground clearance. It appears that this attatches to the axle tube with U-Bolts, and "circles" the bottom of the pumpkin, so I was wondering if it could be mounted upside down?
That is, flipped across the horizontal 180 deg. (with the part that normally goes around the bottom of the pumpkin on top)...
Should I weld up the tubes as well, just weld alone, or what?
Any thoughts?
--pm
post #2 of (permalink) Old 12-28-2001, 03:04 PM
Re: Conferr Axle Truss on top of AMC 20
that shouldn't rob too much clearance but if you can weld why not just make your own truss? Also i think the proper way to weld tubes is 4 1" long stich welds on each tube.
BarrelRoll
97 TJ
Wheel it or drive a minny van
Jeeper99xj is offline
post #3 of (permalink) Old 12-28-2001, 03:36 PM
That thin rod truss is made for tensile strength, and therefore belongs on the bottom. One on top must be made for compressive forces and would be much beefier in design.
Tim
84 CJ7, 258, HEI, M/C 2100 carb, 5 inch lift, RS9000's, 33x12.5 BFG M/T's, 4.56's and Detroit softlocker, full cage & belts, Xenon flares, Dana 44 rear, GM dual diaphragm brake booster
TiminMb is offline
post #4 of (permalink) Old 12-28-2001, 04:00 PM
That type of truss is made to keep the axles from bending from stress, it actually pulls downward on it. No, it won't work on top.
Brad
ORC Land Use Editor
and
