installing lockright into D44? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-2001, 02:04 PM Thread Starter
dennisuello's Avatar
i will be installing LockRight in my rear D44 with 4.56 gears. will i be able to pull the cross shaft without taking the ring gear off? i know in some case you have to grind some teeth a little to get the cross shaft out. i plan on doing it in my carport and will not have access to any powertools. if i have to grind the teeth off, i'll have to arrange with my friend to use his garage and his air tools.
thanks
<>< 1992 Jeep YJ
http://home.off-road.com/~lifted/
dennisuello is offline
post #2 of (permalink) Old 12-28-2001, 02:16 PM
Re: installing lockright into D44?
dont think it will clear with teh ring gear in place.
but I wouldnt grind it off!
marke the carrier bearing caps for up down and side to side ( reinstall exactly as they come off)
simply remove the carrier, take careful note of the shims on either side, marke the ring gear and carrier ( so you can reinstall in teh same holes in case of runout)
remove ring gear, install lockright, slide it back in, retorqe the caps to spec
now youve not changed your gear setup at all, if you reinstalle the shims that came out.
actually on a dana 44 I tihnk teh shims are pressed on between bearings and carrier so there shouldnt be any loose shims, it should be really simple, just reinstall all parts exactly where they came from , just how they were.
OzarkJeep
too small to be seen, and too big to control, and treated like a walking bomb...
ozarkjeep is offline
post #3 of (permalink) Old 12-28-2001, 02:33 PM Thread Starter
what are the torque specs on ring gear bolts and bearing caps bolts?
<>< 1992 Jeep YJ
post #4 of (permalink) Old 12-28-2001, 02:36 PM
you can goto randys ring and pinoion site, or drivetrains page and they have spec charts, sorry I dont know off the top of my head.
youll need teh ring gear bolt torque ( new loctite)
and teh carrier cap bolt torque
OzarkJeep
post #5 of (permalink) Old 12-28-2001, 04:55 PM
I had to take the ring gear off and I only have 3.73's.
'98 TJ Sport-becoming more modified & heavier all the time.
