TJ with 4" lift and 35's? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-2001, 11:52 AM
TJ with 4\" lift and 35\'s?
I was just wondering if anyone is running 35 inch tires with only a 4 inch lift? Tera Flex says you can, but it seems most people also have an additional 1 inch body lift.
Thank you for your input. Rick
'98 TJ Sport-becoming more modified & heavier all the time.
post #2 of (permalink) Old 12-28-2001, 12:09 PM
gigolo's Avatar
Re: TJ with 4\" lift and 35\'s?
I ran 2" suspension + 2" body with 35's and never disconnected the sway bar. It was great in mud and most light trails, and never had a problem with rubbing. I now have the teraflex 4" + a 2" body, and with the swaybar disconnected, I can get them to rub the flares.
BIGJEEPTJ
A man's got to believe in something, I believe I'll have another[img]/wwwthreads_images/icons/crazy.gif[/img]
gigolo is offline
post #3 of (permalink) Old 12-28-2001, 01:54 PM
Thanks. Did you try running them without the 2 inch body lift?
post #4 of (permalink) Old 12-28-2001, 02:43 PM
It's definetally doable though to get a little more room people usually add a 1" body lift or 1" spacer to the springs. Elusive ran a re 4.5" kit on his wife's tj w/ 35's for a while, i think they rubbed a little though not too bad, if you needed more room i bet you could cut an inch off your flares and your fender wells.
BarrelRoll
97 TJ
Wheel it or drive a minny van
Jeeper99xj is offline
post #5 of (permalink) Old 12-28-2001, 04:46 PM
nice pic
Hall
<font color=red>88 Jeep XJ. </font color=red> 30" tires, No Sway bar
post #6 of (permalink) Old 12-28-2001, 05:29 PM
gigolo's Avatar
No, never ran it without the body lift. It was already on, I just took off the 2" coil spacers and put on the tera lift. I would put at least a 1" body with it if you plan to use it for anything more than mud. You'll have room for the tires without eating the fenders, but you'll definitely hit the flares.
BIGJEEPTJ
gigolo is offline
post #7 of (permalink) Old 12-28-2001, 05:59 PM
rick, how much wheel travel do you have with the 31's on a 4 inch lift? Do you have a pic? I have 33's on 4 inch, and my tires stop just before hitting the flare. I want 35's next, but I plan on adding spacers. You'd definitely rub disconnected with 35's on 4
post #8 of (permalink) Old 12-28-2001, 06:51 PM
I was rubbing with 35s and 4" lift at full flex connected. Not too bad though. I guess having sagged springs will also cause to rub. A 4" susp. and a 1" body should keep you from rubbin disconnected though.
JeepTJ1062 is offline
post #9 of (permalink) Old 12-28-2001, 07:10 PM
I have no problems with the 31's rubbing with either the Tera 3 or 4 inch lift (have had both springs)other than with the stock offset and 10.5" wide tires. I have pictures, but they are too big (bytes) to post. I have a tried many times. Rick
post #10 of (permalink) Old 12-28-2001, 10:47 PM
no I knew you wouldn't have any trouble with wheel travel, so wanted to see 31's on a 4 inch lift. could try cropping the pic, works for me
