ignition lock cylinder - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-28-2001, 03:02 AM
im trying to narrow down my ignition problem possibilities, and im going to replace the lock cylinder as a last resort. only problem is i can find how to in any of my books. how might i go about removing it?
War Eagle
post #2 of (permalink) Old 12-28-2001, 06:51 AM
jeepgod's Avatar
Re: ignition lock cylinder
its actually quite simple.. you have to pull the steering wheel off.. and all that crap to release the old one... once you have it out.. the new just pops in.. should be in a chiltons/haynes manual.. i did it some years ago.. and about all i can remember is... it was quite easy.. took about 10 minutes.. but i had a steering wheel puller..
http://www.jeepgod.net
jeepgod is offline
post #3 of (permalink) Old 12-28-2001, 12:10 PM
If memory serves me correct, I believe you have to hit a pin with like a paperclip or something to get it to slide out.
'84 CJ-7, 4.2, 3.5" Lift, 31's, YJ tub, TR upgrade, Moser 1 piece, LED's.
Paddy Whacker is offline
post #4 of (permalink) Old 12-28-2001, 01:55 PM
You need to remove the steering wheel and turn signal mechanism. Put the key in the ignition and rotate it to the first click. Then put a small screwdriver down the access whole hole to compress the black lug on the end of the lock cylinder. Then the lock cylinder just pulls out.I just did this and it's quite easy. While you're at it you might want to replace the ignition switch if you haven't already. After doing these things I realized how easy it would be to steal my jeep.
post #5 of (permalink) Old 12-29-2001, 03:16 PM
Here is what the 1977 non tilt looks like.
this one is LEVE sent me
1977 CJ-7
258/3speed T-150
2.5"lift
and lots of duct tape
&lt;&gt;&lt;
1977CJ7 is offline
post #6 of (permalink) Old 12-29-2001, 03:20 PM
I'm not sure what year they changed, but I know 81-86 lock cylinders are held in by a small phillips head set screw, not the tab. Either way, once you get your steering wheel off you'll see what kind you have.
Brad
ORC Land Use Editor
and
post #7 of (permalink) Old 12-29-2001, 03:47 PM
You don't want to replace the lock cylinder, you want to replace the ignition switch. The switch is located on top of the column accesed from under the dash. A simple 2 screw setup and about a $12 switch.
dorfs is offline
post #8 of (permalink) Old 12-29-2001, 10:42 PM
You may also need to rent the lockplate compression tool ,to get the snapring off to access the lock cylinder.Although someone will no doubt suggest smacking it with a BFH ...,LOL.The right tool just makes everything go sooooomuch easier ,especially reassembly.while you are at it get a puller for the steering wheel ,that works reel well also.
maybe I am just getting OLD
Ray
unhumen is offline
post #9 of (permalink) Old 12-30-2001, 12:14 PM
Does anybody have any ideas for removing the lock cylinder without the key. As I understand it, you must have the key to remove the cylinder and I have a junkyard column with no key. I haven't even tried it yet, so maybe it would be obvious if I looked at it. Just wanted to see if there are some hints.
'75 CJ5 with goodies
'63 CJ6 rolling chassis and body only
post #10 of (permalink) Old 01-01-2002, 04:47 PM
Brad, I've got an '83, and it's got the tab, not the phillips screw.
-Derek Schwab
'97 Sidekick Sport
'83 CJ-7
dschwab9 is offline
