T-18 clutch question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-27-2001, 08:17 AM Thread Starter
To install my Ford T-18, I understand I need a Ford clutch disk that has a 1 1/16" 10 spline instead of a 1 1/8 spline that a Jeep uses. How can I get that package with an AMC pressure plate, other than AA? Will a Ford pressure plate mount to an AMC flywheel?
Thanks
BillR
'86 CJ-7, 360, 727, OEM Dana 44, locked and loaded!
BillR is offline
post #2 of (permalink) Old 12-27-2001, 08:27 AM
Pooh-Bah
pbmcauliffe's Avatar
Re: T-18 clutch question
On my Ford T18 and AMC 304 I used the Ford clutch, pressure plate and disc.
<font color=purple>pbm</font color=purple>
<font color=red>There is a difference between being Educated and Intelligent!</font color=red>
pbmcauliffe is offline
post #3 of (permalink) Old 12-27-2001, 08:38 AM Thread Starter
So the flywheel holes must be a standard pattern. What about the throwout bearing? Standard Ford also? I'm trying to find out if I can use a clutch "package" and what the application would be.
Thanks for the info!
BillR
BillR is offline
post #4 of (permalink) Old 12-27-2001, 08:53 AM
Pooh-Bah
The clutch package I bought at the local NAPA had the wrong throwout bearing with it. I had looked before I left the store, so they pulled one off the shelve and swapped it for me. I think the clutch setup is for older Mustang, (10.4" or 10.5"), throwout bearing is for a Jeep w/4 speed.
post #5 of (permalink) Old 12-27-2001, 11:24 AM
You'll definitely need an AMC throwout bearing. The Ford one won't fit the clutch fork.
Edit - I just remembered that you can get an entire clutch kit for a '77-79 CJ with a four speed and it will have the right clutch disc. Those years used the 1-1/16" clutch disc instead of the 1-1/8" like most other years. I know because that's what I have in mine with a '79 CJ T18.
'75 CJ5 with goodies
post #6 of (permalink) Old 12-27-2001, 12:44 PM
BillR
So you have the T18 Ford with the AA adapter ? Was it together or did you install the mainshaft yourself ? D20 or D300 and how long is the whole assembly going to be ? I`m slowly attempting this whole manouver myself . Mine is going in a CJ5 so I`m wondering how long my driveshaft is going to be ? If I`m going to end up welding 2 universals together for a driveshaft [img]/wwwthreads_images/icons/tongue.gif[/img] I`ll wait for a Jeep T18w/D20 . What about your skidplate ? You just moving it back to the last set of bolts ? Thanks for any tips Bill.
<font color=black>Jeff [img]/wwwthreads_images/icons/cool.gif[/img] </font color=black>
Jeepzilla is offline
post #7 of (permalink) Old 12-27-2001, 12:52 PM
Pooh-Bah
Jeff- In my 75 CJ5 w/SOA, T18/D20 I had a standard 17.5" long rear driveline, and moved the skid back to the next set of holes. Front shaft was lengthed 3".
post #8 of (permalink) Old 12-27-2001, 02:18 PM
Thanks Patrick , if my 79 follows the same lines there should be no problem . Are you using the Ford with adaptor or Jeep T18 ?
post #9 of (permalink) Old 12-27-2001, 02:46 PM
Pooh-Bah
Ford T18 with 1" adaptor made locally.
post #10 of (permalink) Old 12-27-2001, 04:04 PM Thread Starter
Jeff-
I pick the tranny up on Saturday. I can let you know more then.
BillR
BillR is offline
