Steering shaft - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-26-2001, 09:42 AM
Steering shaft
HAPPY HOLIDAYS TO ALL!!!
i am trying to disconnect and/or remove the steering shaft in my 83 CJ w/auto xmsn. i have removed the plastic pins to try and collapse the shaft but no joy. the clamps at both ends are loosened and i want some opinions on which end to try and release and how. TIA and Happy New Year.
Bob
[img]/wwwthreads_images/icons/cool.gif[/img] 83 CJ-7 [img]/wwwthreads_images/icons/cool.gif[/img] <font color=red> IF YOU AREN'T LIVIN' ON THE EDGE YOU'RE TAKING UP TOO MUCH ROOM! </font color=red>
<font color=blue> Quitcher Whinin' </font color=blue>[img]/wwwthreads_images/icons/wink.gif[/img]
post #2 of (permalink) Old 12-26-2001, 10:01 AM
elusive's Avatar
Re: Steering shaft
feeling shafted???LOL ....unbolt the box from the frame and it will give you just enough room to get the shaft out...
~~Elusive~~
everything good in life is round, breasts, halos, and headlights
http://www.jeepgod.net
elusive is offline
post #3 of (permalink) Old 12-26-2001, 10:02 AM
Re: Steering shaft
Last time I pulled my shaft out I had to remove the steering box, it cam off the column end easily then, was a pain to get off the box end.
Brad
ORC Land Use Editor
and
post #4 of (permalink) Old 12-26-2001, 10:33 AM
Re: Steering shaft
Funny enough, I had this problem. I used a little torch and heated up the shaft and keep trying at it.
84CJ7 SOA,35's,OnboardAir,Dual winches,Full Cage,Snorkels, and more
OverMost 4WD Club
post #5 of (permalink) Old 12-26-2001, 11:56 AM
Re: Steering shaft
THANX i figured taking off the box was the next step.
i was just trying to learn a short-cut if there was one out there
thanks again and Happy New Year
Bob
post #6 of (permalink) Old 12-26-2001, 01:39 PM
Re: Steering shaft
No need to remove the box.
The splined steering shaft in the column retracts into the column. It's most likley stuck. It's been a while but some WD40, needle nose vise grips, a screwdriver and a hammer did the job. Start off by taking out the clamp bolt, move the shaft sleeve down as much as you can, then gently pound the splined shaft back up into the column. Keep playing with it, it'll go.
CTjeepnut
You had to do what to fit those little tires?
I'm sure glad I own a CJ!
post #7 of (permalink) Old 12-26-2001, 02:35 PM
Re: Steering shaft
Loosen the column support bolts under the dash. The column assy will slide rearward enough to remove the shaft.
No need to drop the steering box or collapse the shaft.
1976 CJ7 304/TH400/QT/D30/AMC20
Front D44 in process.
JeepDaddy is offline
post #8 of (permalink) Old 12-26-2001, 02:38 PM
Re: Steering shaft
that's what i like alternative ways to invent new curse words, thanks to all
Bob
