-   Jeep-Full Sized (https://forums.off-road.com/jeep-full-sized/)
-   -   AXLE SWAP (https://forums.off-road.com/jeep-full-sized/92937-axle-swap.html)
**DONOTDELETE** 10-30-2001 01:53 AM
AXLE SWAP
I'M PLANNING ON SWAPPING THE FRT 44 AND RR 60 FROM A 78-79 F250 TO MY 84 WAGGY. ANY SUGGESTIONS. WHAT TRANSFER DOES THIS TRUCK HAVE?
BUILD-IT-DONT-BUY-IT.
**DONOTDELETE** 11-04-2001 03:45 PM
Re: AXLE SWAP
If the truck is part time 4x4 it will have the NP205(Very Strong,1.96:1 low). Stay away from full time 4x4, the T-case in those are the NP203, and they're worthless. Also don't go to the earlier Fords(77 and earlier)because the t-case is divorce mounted. Good Luck.
78 CJ5/360/33's
**DONOTDELETE** 11-04-2001 06:29 PM
Re: AXLE SWAP
HEY, THANKS FOR THE INFO. I'LL DOUBLE CHECK TODAY.
Jeeper99xj 11-11-2001 02:19 PM
Re: AXLE SWAP
if you are going for super beef get a d60 front the ford d44 isn't that much stronger, you could probably sell both d44's for the price of a 60, some f350's came w/ rr d60 fronts which are as strong as they get, super beefe and almost unbreakable. What size tires are you planning on running? if 35's are the biggest w/ a mild motor a 44 might be alright if you take it easy but bigger than 35's i wouldn't risk it.
BarrelRoll
97 TJ
Wheel it or drive a minny van
**DONOTDELETE** 11-12-2001 02:22 AM
Re: AXLE SWAP
I'M PLANNING ON RUNNING 36 OR 37'S ON A HIGH MILD ENGINE. THE 44 PROBABLY WONT LAST LONG. I'VE GOT TWO FRONT D44'S. OEM VACCUM OPERATED FROM GW AND HUBED FROM A LATE 70'S F250. ANY ON INTERESTED IN SWAPPING FOR A FRT D60?
**DONOTDELETE** 11-12-2001 02:56 PM
Re: AXLE SWAP
I think the d44 in front would be fine with 37's! Mine withstood TONS of abuse when I had the 35x14.5's on 14" wide rims with bead locks. There shouldn't be any prob at all unless you are an ARCA contender!!!
"The Great Pumpkin"
77 Cherokee/SOA/35's
96 XJ/3"/31's
