77 wagoneer noises...Amended - Off-Road Forums & Discussion Groups
Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck
post #1 of (permalink) Old 07-02-2001, 03:02 PM
Allular
1977 wagoneer, 360, automatic w/ quadratrac...
i've developed a pinging/clunking sound when under load on my wagoneer. it only does it in gear. park and neutral are fine. i can idle around with no noise but once under load it makes the noise. it sounds like it's coming from the bell housing area. any ideas? thanks
post #2 of (permalink) Old 07-10-2001, 02:59 PM
Re: 77 wagoneer noises
Sounds like your QT chain is in need of replacement. There is an access hole at the bottom of the case to check how much slack is in the chain. If it's over 1/2 to 3/4", replace the chain.
post #3 of (permalink) Old 07-10-2001, 11:13 PM
Is it more like a racheting sound? If it is the chain, it will "clunk" once or twice at first, but it will keep getting worse. The chain is loose enough to jump the sprockets.
Chris
post #4 of (permalink) Old 08-23-2001, 08:35 PM
Allular
Thanks guys. The sound is more like some one put a metal on my drive shaft or a screwdriver in the fan. The sound is not a single clunk or ping. It's consistent with the engine's speed. I've been leaning toward a flywheel/torque convert problem. One other note, shortly after the noise started an oil leak developed in the bellhousing/rear end of the engine area. Am I on the right track? Thanks again.
Uhhuh
