-   Jeep-Full Sized (https://forums.off-road.com/jeep-full-sized/)
-   -   Lockrite Install Help! (https://forums.off-road.com/jeep-full-sized/74802-lockrite-install-help.html)
**DONOTDELETE** 06-15-2001 10:38 PM
Help with Dana 44 Lockrite install. If anybody see's this soon and wouldn't mind I would like to talk to them about this on a land line. I have the diff open now and I'm stuck!!
Thanks,
Chris
If it can't be done from the seat of a Jeep, it don't need to get done!
**DONOTDELETE** 06-16-2001 01:15 PM
Re: Lockrite Install Help!
call me and I will see if I can help you out.
580-762-5611 ext.14
Ranger
blackjeep2002 06-20-2001 09:18 AM
I did one in my 78 Cherokee and it was pretty simple. The instructions with the Lockright are pretty good. If you have the thick ring gear (case 3.92 and down), you will need to remove the carrier from the Jeep to do the install. Just be sure you keep the bearing caps and bolts in the same position for reinstallation and you should be OK. Also, make sure you use Locktite on the ring gear bolts when you put it back together. Call if you need to:920-445-0204.
Keith
