How do I shift my Quadratrac - Off-Road Forums & Discussion Groups
Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck
post #1 of (permalink) Old 06-10-2001, 02:58 PM
I just bought a '77 jeep pickup with a 401,auto tranny, and quadratrac t-case. I found the shifter under the seat, but I can't seem to get it into low gear, what am I doing wrong?
Also, could anyone tell me what model transmission I have?
thanks.
78 CJ5/360/33's
post #2 of (permalink) Old 06-10-2001, 05:41 PM
Re: How do I shift my Quadratrac
The low range lever can only be shifted to low when your TH400 trans is in neutral.... then you put it back in D and you have a 2.57:1 low range.
Coming out of low range, you don't need to stop but neutral must be engaged in the trans at about 5-10 MPH to get back to hig range...you can stop ...but no need.
78 Wagoneer
14" total lift
4.89's/Lockers/39.5" Swampers
http://home.earthlink.net/~tjnkk
post #3 of (permalink) Old 06-10-2001, 07:29 PM
thanks for the info, but where is low on the pattern? all the way up? all the way down?
also, can I use parts like a deeper tranny pan, or shift kit made for the chevy th400?
78 CJ5/360/33's
post #4 of (permalink) Old 06-10-2001, 11:45 PM
On a truck the "up" position is the low range position. It is a 3 position set up. Up = low, middle = neutral (used only if you need to flat tow) and down which is high range/normal driving position.
Why drive a luxo-box SUV when you can lay in the dirt busting your knuckles under old iron? '77 CJ-5, '64 S2A Land Rover
badvibrations is offline
post #5 of (permalink) Old 06-11-2001, 08:02 PM
It helps if the vehicle is rolling under 3mph with the tranny in neutral when you shift into low range.
Chris
post #6 of (permalink) Old 06-13-2001, 07:57 PM
The guys are both right about the shifting procedures...a good tranny shop should be able to help with pan interchangeability..sorry, can't help there.
Dan
'67 8701 Deluxe
JEEPSTERS and their Owners - Friends for Life.
dan01ster is offline
post #7 of (permalink) Old 06-13-2001, 09:50 PM
The t400 in the jeeps is the same T400 as the Chevys. Only difference is the case has the special bellhousing for AMC engines. Other than that, the guts and oil pan are all GM.
Chris
