Axle Wrap bars...Pics - Off-Road Forums & Discussion Groups
Jeep-Full Sized All discussion of full sized Jeeps: Wagoneer, Full Size Truck
post #1 of (permalink) Old 05-10-2001, 11:24 AM
I have been busy fabbing parts for my FSJ...since I needed re-enforcements on the drivetrain. The difference with the axlw wraps is AWESOME...much more instant power to the ground and rapid repsonse is very noticeable. I will be fabbing a "hinged" front mount soon cuz the solid front mount does limit articulation a bit... if you run 35's or better I HIGHLY suggest fabbing a setup or buying one if you can find one. JC Whitney sells a setup for $67, but won't fit a lift over 4"... well worth the $$$...
78 Wagoneer
14" total lift
4.89's/Lockers/39.5" Swampers
http://home.earthlink.net/~tjnkk
post #2 of (permalink) Old 05-14-2001, 11:07 AM
Re: Axle Wrap bars...Pics
Hey you have an awsome truck, what kind of axels are you running??? Would you by chance know where I could get a 1ton D60???
"Unpassable when wet"????? Whatever
post #3 of (permalink) Old 05-14-2001, 03:44 PM
Dana 44's front and rear with Detroit lockers and 4.89 gears.
I don't know of any 1 ton's layin' around sorry....Thanks for the compliment...
78 Wagoneer
14" total lift
post #4 of (permalink) Old 05-14-2001, 04:12 PM
Clean instalation...But how do you plan to hinge them? I've seen similar setups using old shackels at the front to allow them to swing, But under real heavy acceleration the bar would pull back and alow the spring to wrap up. You might be better off just goung with an ovesized hiem joint(something with a bigger hole than the bolt) although it might get a little noisy.
jimmythetech is offline
post #5 of (permalink) Old 05-29-2001, 04:50 PM
Use a joint for a 3-point-hitch deal off a tractor. Get one with a zerk fitting. You can pick them up at about any tractor store for cheap, and they are strong!
Sycho15 is offline
