-   Jeep-Full Sized (https://forums.off-road.com/jeep-full-sized/)
-   -   Turn Signal Switch / Steering Column question. (https://forums.off-road.com/jeep-full-sized/156244-turn-signal-switch-steering-column-question.html)
**DONOTDELETE** 03-03-2003 03:45 AM
I pulled the steering column out of a junked 85 Wagoneer for my Jeepster. On the way home, the plastic turn signal switch assemble inside the column got broke. Can anyone here tell me how or where where I can find the disasembly instructions for the column to get to the switch? I pulled the wheel and the plastic cover that sets over the steering wheel lock, but I can't see how to get it any farther apart. I don't want to damage anything in the process of trying to replace the switch.
Thanks in advance for any help.
Dan
Andytron 03-05-2003 07:25 PM
Re: Turn Signal Switch / Steering Column question.
If you have a shop manual for a mid 80's GM car or truck the procedure should be real close if not the same. Or get a Chiltons from your local library.
ozarkjeep 03-08-2003 02:15 PM
you need a "lock plate spring compressor" autozone loans them, it allows you to comrpess that plate that lockes the thing in Park, and remove the littel ring that retains it on teh steering shaft, then it all slides off and you can easily see the $19 blinker switch, its used on about 4 million cars in America since its a GM column, and should be avaiable nearly everywhere.
you may want to take it with you , its likely the parts monkeys wont try hard since its just an "old Jeep", but if you walk in with it and say its form a 1981 Chevy truck, they will have it for sure!
its comon to strip the screws out that hold it in also, I usually put a dab of red loc-tite (242) on the threads and just get them snug.
good luck
