-   Jeep-Full Sized (https://forums.off-road.com/jeep-full-sized/)
-   -   D44 axle questions (https://forums.off-road.com/jeep-full-sized/117924-d44-axle-questions.html)
BillM 04-28-2002 07:35 PM
D44 axle questions
Ok. Here's the deal. I had 2 d44 front axles from 77-78 wagoneers. 1 had lockouts and 1 was fulltime. I pulled them both apart and put the stuff together. Now the problem. I'm putting the axle under the jeep back together but one set of spindles had a smaller inner bearing and the other has a larger inner bearing. Which is for which? The spindles are the same length but have different setups(shorter) where the inner bearing sits. Everything else is the same though. Can I use the spindles with the larger bearings or is there a difference that I don't see. I'll be using the lockouts. Thanx.
Bill
