auto-lock hubs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-21-2001, 09:54 PM
auto-lock hubs
I am fairly new to IH...and I have a '78 traveller 4x4...What is auto-lock?...On the hubs it has lock...and then as you turn the hub... auto lock...also on the pass side hub it looks different(the hub) and has marked...2w and 4d.
This may seem stupid...but i need to learn...Thanks
Do It Now,Before Regreting Never Having Done It.
post #2 of (permalink) Old 05-22-2001, 11:40 PM
Carpal \'Tunnel
NoBucks's Avatar
Re: auto-lock hubs
This is from the Binder Bulletin:
IH Scouts were shipped with at least two different styles of automatically-locking front hubs. These two styles were designated "Lock-o-Matic" and "Auto-Matic".
These hubs have two dial positions, labeled "AUTO" and "LOCK". ("FREE" and "LOCK" on the "Lock-O-Matic" hubs.) When in "LOCK", the hubs function just like a manually-locking hub. When in "AUTO" or "FREE", however, these hubs will free-wheel until torque is applied to the front axle shafts. When the transfer case lever is pulled, and torque is applied to the front axle drivetrain, friction pads are engaged inside the hub and the hub acts as though it were locked. This locking action is effective in both forward and reverse, just as in the case of a manually-locking hub. The only circumstance where these hubs are NOT locked (when a manually-locking hub WOULD be) is under engine- or compression-braking.
A thin coating of light grease is sufficient for the internal parts of any "selectable" hub style. Automatic locking hubs, however, are particularly vulnerable to failure from over-greasing. Packing the entire hub interior with thick grease can prevent the hub fron disengaging properly. One or more hubs that fail to unlock properly can cause the entire front drivetrain to be "driven" in reverse from the rolling tires, even when the transfer case is in 2WD.
Bill Thebert
The Binder Bulletin
Joel F.
Marquette, Michigan
Project No-Bucks
'68 Jeepster Commando
'79 Scout Traveler
NoBucks is offline
post #3 of (permalink) Old 05-23-2001, 06:43 AM
Re: auto-lock hubs
Thank you so much for that in depth explanation.
