More RPM? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-13-2001, 10:09 AM
More RPM?
I was reading some tech tips and I saw some stuff on getting more rpm out of your IHC engine...It said get some Chrystler 340 valve springs and some retainers, or some Chevy 340 valve spring and retainers (or something close to that).. It said that with the right cam you should be able to get about 5000 rpm out of it....But what would the right cam be? And would you loose torque switching cams? Or any other IHC attribute?
post #2 of (permalink) Old 03-14-2001, 01:24 PM
Re: More RPM?
I've been told the 340 springs are inadequate and might not even be as good as the stock springs on an IH.
You need to look at BigBlock Chevy valve springs. If you want a lot more RPM, get the LS6 BBC springs. I bought everything I needed from http://www.GryphinRacing.com - springs, retainers, keepers, etc. They go right on with no modifications.
The stock cam doesn't breathe very well when you get up near 5000rpm. I built my 345 with an Isky 262/262 grind and it'll happily spin 6,000rpm. I bumped the compression up just a bit (somewhere between 8.5 and 9:1) in an attempt to make up any lost bottom-end.
It still pulls very well at idle - but get it to 1000rpm or so and it'll REALLY pull. It doesn't stop pulling even at 5500-6000rpm.
I also balanced the reciprocating assembly and ported the heads to take better advantage of the higher RPM. I'm using the LS6 springs.
-Tom Mandera, Helena MT
http://www.tmcom.com/~tsm1/scout
tsm1mt is offline
