35 inch tires - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-17-2000, 03:49 PM
35 inch tires
What is needed to put 35's under a 74 scout II, I have 4" springs 2" Body and extended shackles to put on it, will I be able to fit 35's.
post #2 of (permalink) Old 10-18-2000, 03:41 PM
Re: 35 inch tires
"maybe"
Are you putting extended shackles on the FRONT? You'll have negative caster and horrible handling unless you put some caster shims in to correct for the change.
I think you should certainly clear 33s pretty well with a 4" lift + 2" body lift. 35s.. mebbe.
Certainly if you lower your bump stops to keep the tires out of the body. I imagine the worst place you'll rub is in that 30.5" across rear wheel well.
tsm1mt is offline
post #3 of (permalink) Old 10-24-2000, 03:53 AM
Re: 35 inch tires
http://www.binderbulletin.org/faq/19.htm#1
here if you haven't seen this you should read it
Bindernut
