Disc Brakes aren't Brakin!!!!! HELP - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-17-2000, 04:10 PM
Corey-88K5
Disc Brakes aren\'t Brakin!!!!! HELP
Well I got the new TSM Disc's in stalled and lines are blead, but now I've got a problem. The caliper pistons only move about 1/4" and then retract. They don't even contact the rotor enough to stop the rear axle when its off the ground and in drive. The main problem seems to be that the caliper pistion doesn't act like the front. When you pump the brakes they just go in and out, not contact the rotor than apply pressure to stop. Does anybody have any suggestions? These are 85 Eldorado calipers. If anybody has any knowledge of the rear system, please let me know. I tried to push the reset button on the proportion valve. I'm not sure if it has to be held in when doing this.
Thanks,
Corey
88K5
[img]/wwwthreads_images/icons/laugh.gif[/img]<font color=red>Girls Like Guys In Bow Ties
http://www.geocities.com/corey_perez
post #2 of (permalink) Old 06-17-2000, 09:51 PM
Re: Disc Brakes aren\'t Brakin!!!!! HELP
I had the same problem when I installed the TSM kit on my Scout. The reason for your problem is that the
Eldorado calipers are not self-adjusting like front calipers - they need to be adjusted after you install them.
To do this, remove the bolt that holds the parking brake lever on the caliper, and remove the lever. Then use
a wrench to tighten the shaft as far as possible - this will move the pads' resting position closer to the rotor.
You also need to have the ebrake cable installed, and use it periodically in order to keep the calipers adjusted
as the pads wear.
Later,
Curt
post #3 of (permalink) Old 06-18-2000, 03:48 PM
Corey-88K5
Thanks Curt.
I'll give that a try when I get a chance on Monday.
Corey
88K5
