GVW of a 1977 Scout - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-10-2005, 01:39 PM
slaroche
GVW of a 1977 Scout
Can someone post this information? I keep seeing between 6100 and 6200lbs, but that seems like a lot. My Tahoe weighs 6900lbs.
post #2 of (permalink) Old 01-11-2005, 09:09 AM
slaroche
Re: GVW of a 1977 Scout
In case anyone cares, it's ~3500lbs
post #3 of (permalink) Old 03-15-2005, 11:39 AM
IH_Scout_II_Fan
Hi,
I just bought a 1972 Scout II. Do you know how much they weigh? I looked at the VIN tag, but it didn't have any info on weight.
I'm curious if 2-ton capacity bridges will be a problem.
Thanks,
Russ
post #4 of (permalink) Old 03-15-2005, 11:15 PM
Robert B
Weight will vary between 3850 and 4200 lb, depending on body style and equipment. I had my 71 Scout II weighed, gave the guy $5. No charge to weight my 79 Scout II Traveler at a junk yard (auto parts recycler) where I had just bought parts.
post #5 of (permalink) Old 03-19-2005, 11:06 AM
Hunter57
GVW isn't what the vehicle weighs...it's the Gross Vehicle Weight rating. In other words, how much they weigh, plus how much you can load on them (including yourself...lol...), plus whatever tongue weight you are dragging behind them. It determines the emissions class they are in, and it's mostly a function of axle and spring ratings.
My old 77 Scout II with roll bar, accesories, and winch wighed 4450 last time it went over the scales; the 76 Traveler I used to have only weighed 4180 lbs with just my miscellaneous junk in it, but it was stone stock. The GVW for both of these was listed at 6200 lbs, so I could have put about a ton of stuff (literally) in or on both of them without exceeding the weight limit rating. I have a friend with a 76 half cab Scout II with the 4 cyl, and his also has a 6200 lb weight rating, but I don't think I'd want to do that much weight with the 196 4 cyl.
post #6 of (permalink) Old 03-20-2005, 02:26 AM
Hunter57
Folks, I had a small brain blip earlier; Scout II GVW after 74 is 6200 not the 6500 I had stuck in my mind for some reason...sorry I put it down wrong, and I went back and I edited it to the right GVWR. [img]images/graemlins/wall.gif[/img]
I currently have a 79 Traveler, also a 6200 GVW, but I've never run this one over a scale, and it's a little more loaded than the 76 (AC, cruise, winch, aftermarket pwr windows, etc.) so it probably weighs in at a lot more than the 77 Scout II did.
Sorry for the 300 pound "oops" earlier; I should have looked at the tag on the Traveler to be sure before I posted. [img]images/graemlins/chair.gif[/img]
