scout trannys - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-10-2000, 06:56 PM Thread Starter
scout trannys
Hi all!
I've got a scout question,so might as well ask the scout boys!I found a bunch of scouts at a scrap yard and I was looking at a 78 and a 79 both with 4 speeds.One had the slant 4 and the other had a v8.My question is:what are the trannys t18,t19 or what?what are the gear ratios on those trannys and will they bolt up to an amc 360?Thanks guys!
Ben
ps let me know if you want to know where the yard is!
winchboy is offline
post #2 of (permalink) Old 02-10-2000, 07:20 PM
Re: scout trannys
Ben,
They're T19s, and they could be either the wide ratio (6.3:1 first gear) or close ratio
(4:1 first gear). They should be plenty strong enough for a 360.
Later,
Curt
post #3 of (permalink) Old 02-10-2000, 09:09 PM Thread Starter
Re: scout trannys
Thanks curt,
On t-18s there are long and short input shafts.Is this the case as well with the t-19s?I read somewhere that the deep gear on the t-19s was in the 5:1 range not 6.32 is this true?Thanks.
Ben
winchboy is offline
post #4 of (permalink) Old 02-10-2000, 11:25 PM
Re: scout trannys
I got a t-19 out of a 79 scout that was behind a slant 4. It had ~4 to 1 first gear. And i dont believe it would bolt to the jeep bellhousing. In the wreck yards look for scouts with a inline 6. it is the amc 258, so the scout bellhouing and tranny will bolt up to the amc 360. the bellhousing/input shaft will likely be longer (shorter rear drive shaft?). also get advance adapters catolog - good info
post #5 of (permalink) Old 02-11-2000, 12:51 PM
Re: scout trannys
All of the T18s/T19s from Scout II's should have the long input shaft. I checked my wide T19
before I installed it, and 1st gear is definitly 6.3x:1. I wouldn't be surprised if there are T19s in
Fords that are 5:1.
Later,
Curt
