electrical - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-03-2003, 05:57 PM
electrical
when i attempt to start my car nothing happens, no noise or anything, when i tried to complete the circuit on the starter solenoid the starter did not crank over but there were sparks present. my battery connections seemed allright any suggestions as to whats wrong with the scout. thanks, hirsh bo [img]images/graemlins/givemebeer.gif[/img]
post #2 of (permalink) Old 01-03-2003, 09:45 PM
Aprentice
4x4Freak's Avatar
Re: electrical
For one thing, its feelings are hurt for being called a car. If all the connections are good and the battery is fully charged, pull the starter out and have it tested somewhere. If it tests good then there is most likely a problem in the circuit that kicks the starter in.
4x4Freak is offline
post #3 of (permalink) Old 01-07-2003, 03:58 PM
Re: electrical
First of all, see if your starter is good, and that you at least have a good solonoid. If your solonoid is mounted on the starter try sticking a screwdriver, wrench or anything metalic to jump the connection between the wire that should go to your ignition switch and the terminal that the battery cable goes to. If you just get a click and the engine doesn't even attempt to turn over then that means you have a bad solonoid, and replace it. You might as well go and replace your whole starter but if you're cheap like me just replace the solonoid.
Just depending on your current situation with your scout you might want to install a new ignition switch, ignition and starter wires, and a new starter with a new solonoid.
This is exactly what I had to do with my truck to get it going again, except I only had to replace the solonoid.
