-   GM Standard SFA Trucks & SUV's (https://forums.off-road.com/gm-standard-sfa-trucks-suvs/)
-   -   Always something (https://forums.off-road.com/gm-standard-sfa-trucks-suvs/235204-always-something.html)
c_rock 11-05-2010 08:40 PM
Always something
Man, there is always something that needs fixing on the Burb. Yesterday the battery crapped out. I knew it was on its last legs, it was starting real slow. I tried to charge it with no luck, so I took it in and got a replacement. The old one was 7 years into an 8 year warranty, so not a big deal. I put the new battery in and the truck won't start, just a single click. I figured it was the starter, and sure enough that was the problem. I'm fairly certain it was the stock starter from 1989! I also noticed that the main lug on it was real loose, so I think that was what caused my intermittent electrical problems.
So for now, all is good in the world.
texas sub 11-07-2010 01:05 AM
Don't feel bad mine wasn't starting so I put adapters to change from side mount to top mount on the batery. Then the water pump went then thermastat now the rearend is gone. Almost feel like goin and geting a new truck. O and the wifes sub has tbi that's runnin to rich. And finaly one of the prior owners removed thegears out of the front axel. But I remember the look on a guys face that was stuck in his brand new hummer as I pulled him out. He spent to much thinkin that hummers where the beat all in offroad and I told hime I only had five grand into my sub. Poor guy looked sick.
c_rock 11-09-2010 04:31 PM
I'm not too worried about it, at least I don't have to make any monthly payments on it.
It seems like the problems all happen at the same time, kind of like you're talking about. My steering box is leaking so bad I have to refill it every day. I need to rebuild or replace it pretty soon.
texas sub 11-10-2010 03:07 PM
Got one off 81. Want it? As far as I can remember didn't leak. I don't think I can use it becaus mine is metric. Either way mines good and the spare is a door stop right now. Got the pump too.
I've got to find 3" drop pitman arm. My son gave me a choice. 1 tons and the rear fender extension or 10 lug mystery axels. I believe they are off a 2 1/2 or 5 ton. Not sure I've already got some 44" on some off-set rims. Only problem other then rims and tires for the heavy axel would be moving spring perches and configuring the steering set up. Any ideas?
c_rock 11-11-2010 04:17 PM
Thanks for the offer but I just picked up a box yesterday.
Are they military axles? You'd probably have to weld on some spring perches and shock mounts, fabricate cross-over steering (I think you'll need a 2wd steering box for that), and find some kind of a conversion u-joint or custom drive shafts.
texas sub 11-15-2010 07:52 PM
Not sure where theycame from as far as steering and drivelines, the driveline will go to a drive line shop let them have fun balancing it. I work in a mechine shop so the crossover steering should be fairly quick to build just waitin on materials and money.
