Is there a way to replace the knuckle studs? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-10-2006, 04:29 AM
namseulb
The one that holds the steering arm.Or do I have to replace the whole knuckle?Mine popped off and the other two are loose.The nuts are seized to the stud with the cone.Now my car has no left turn [img]/ubbthreads/images/graemlins/frown.gif[/img]
post #2 of (permalink) Old 01-10-2006, 03:45 PM
raelayotte
Re: Is there a way to replace the knuckle studs?
yes heat then up
post #3 of (permalink) Old 01-10-2006, 09:51 PM
'86k5
a good penetrating lube will do it
post #4 of (permalink) Old 01-13-2006, 10:29 AM
First what are we working on????
snowmancat is offline
post #5 of (permalink) Old 01-13-2006, 04:01 PM
namseulb
86 Burb
6" lift
steering arm correction
Dana 44 front
cheap Warn(plastic) hubs in the front
Can I install the studs without removing the knuckle?(coming from the top)..The dealer wants $17 bucks(CAN) for the studs and $27 for the cones..I was originally quoted at $80 and $90 respectively..dealers here in Toronto are nuts.
post #6 of (permalink) Old 01-14-2006, 10:22 AM
This Is what I did when I snapped mine. I snapped all three of them off, so I took a welder and welded a nut to them and pulled them out then I bought some bolts the same NC thread that fits (can't remember the size) but I then put the little cones on them and tightened the holly crap out of them with a 1/2 bar and a piece of pipe. As far as the cones go do you guys have a junk yard? they are a dime a dozen around here. Anywhoo I hope that helps if not let me know. good luck
post #7 of (permalink) Old 01-14-2006, 11:07 AM
namseulb
So, do you need to take the knuckle off?Or would the bolts fit right through ?...thanks
post #8 of (permalink) Old 01-20-2006, 08:00 PM
you don't have to take the knuckle off sorry
