'84 Sub:Poor air flow through vents and defrosters - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-20-2005, 01:45 PM Thread Starter
DaveGoodrich's Avatar
\'84 Sub:Poor air flow through vents and defrosters
I don't get much air going to either the dash vents or the defrosters on my '84 suburban. On either setting, most of the air still goes out the floor heater ducts, although the controls do have some effect. I am guessing that there is a flap inside the heater box that is supposed to direct the air, and either it is not moving completely, or it has a seal that is worn out.
Can anybody give me any guidance on how to diagnose and repair this?
DaveGoodrich is offline
post #2 of (permalink) Old 10-21-2005, 09:31 AM
Re: \'84 Sub:Poor air flow through vents and defrosters
when you move the vent selector, does it feel loose in anyway? your body style used mechanical hinge thingys to close and open the airflow and youd be able to feel if they were loose. If thats the case then youve gotta go under the dash and repair them. the repair should be simple but getting under the dash to the right place will be a pain in the butt. i dont think there is a seal that is worn out, b/c those units work like a butterfly on a throttle body. it could also just be a bad blower. let me know how it goes.
TNCowboyPRCA is offline
post #3 of (permalink) Old 10-21-2005, 09:52 AM Thread Starter
Thanks for the info. The control moves easily, but doesn't seem totally loose (like a broken cable). Like I said, the control does have some effect (some air comes out the defroster or dash vents, depending on where the lever is set, but most of the air comes out through the floor ducts, no matter where the lever is set.
Thanks again,
Dave
post #4 of (permalink) Old 10-21-2005, 01:42 PM
I have a 86 Silverado pickup and the heater is controled by vacuum operated doors in the system. My guess is one or more of the rubber hoses have dried out and split under the dash or under the hood. There should also be a black (kind of round shaped) vacuum storage canister under the hood on the drivers side near the hood hinge. That sometimes cracks and if there's no vacuum then the heater doors won't work.
Good luck...
Wishin2BTrackin is offline
post #5 of (permalink) Old 10-22-2005, 01:45 PM Thread Starter
Thanks, the vacuum thing sounds like a likely source of the problem. I will take a look today. Hopefully, I won't have to take the dash apart to find the hoses.
Thanks again,
Dave
