Lifting Blazer? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-08-2004, 07:55 PM
offroadrage
Lifting Blazer?
Hey i was wondering what is the easy way to lift a 90 blazer full size i want to fit 36-38's. I don't know if they come stock with a spring-over or not, but it has one. I noticed the leaf springs are really weak and there are only two leaf's to each spring. I was thinking of getting the spring rearched and mabey adding a couple of leafs. Tell me what you think. Thanks~Matt
post #2 of (permalink) Old 12-08-2004, 09:24 PM
gregmgm
Re: Lifting Blazer?
My suggestion would be to buy new spring pacs. It would make more sense than re-arching and adding leafs to your old springs, and they'd be designed better anyway. If you go this route, get high quality ones with anti-friction pads between the leafs, so it'll ride smoother. Good leaf pacs have more, thinner leaves than older pacs, which have only a few thicker leaves.
post #3 of (permalink) Old 12-08-2004, 10:23 PM
Re: Lifting Blazer?
Yes, spring over is stock. 6" front lift springs, rear shackle flip (do a search), and you're good to go for 36s. That's about all you should put on your axles (asuming they're the stock 10 bolts).
post #4 of (permalink) Old 12-09-2004, 12:59 AM
TxFireman's Avatar
Re: Lifting Blazer?
Are you wanting to do some serious wheeling.... or just some mild goofing off?
Are you looking for lots of flex... or just lift?
TxFireman is offline
post #5 of (permalink) Old 12-09-2004, 01:19 AM
Re: Lifting Blazer?
Only two leaves? What kind of springs are on that thing?
newxjer is offline
post #6 of (permalink) Old 12-10-2004, 09:51 AM
offroadrage
Re: Lifting Blazer?
med to heavy off-roading. I got a donor truck it's like a mid 80's suburban i think they have 3/4 ton axles? I want a little bit of both i like to climb, and mud. Can anyone point me to a kit under $600, or sould i just piece one together?
post #7 of (permalink) Old 12-10-2004, 08:56 PM
TxFireman's Avatar
Re: Lifting Blazer?
I don't think you'll like it if you're wanting to get some good flex from it.
Tuff country makes some 4" EZ ride front springs that flex good, and it's what a lot of K5 owners use. Custom springs can be made better, but the TC have good flex for a good price. There is also the option of putting the rear springs up front, and removing a couple of leafs... that's good for 4" and great flex, maybe even a little too much if it's a daily driver. Then replace the rear springs you used up front with 56" rears from a truck.. add in a shackle flip. There are a few options options to go with. 4" w/ 36 will be fine... I was wanting to run 38.5's with 6", but unless the springs are custom, it's hard to get 6" springs to flex the way I want.. so, I may be using the TC 4" springs up front, and a flip in the rear. Maybe even a 3" flip with some 56" 3" springs.. as you can see, it can get very involved.
The plain ol out of the box lift kit, even for a SFA GM, is not what it's cracked up to be for wheeling. To be honest, if you really want to wheel the thing, I would honestly have to suggest a forum that deals with your type of vehicle, and that has lots of experience with making it ready for just that. Ck5 is a good place, pirate, even austink5.net, although there are not nearly as many members there, has some people who's brains you could pick. The flex you can achieve from good springs will really help for you're climbing etc, and won'y hinder you mud fun. If you were just going to stick to mud, then flex would not be as much of an issue. Whatever you do, if you plan to climb, remember that you want to keep your center of gravity low... there is a reason you don't see rock crawlers running 12" lifts w/ 44's.... let the mall cruisers do that, and stay away from that BS. Be prepared to trim some fenders if you plan to get some flex, since having a low center, and big tires will require you to.
As for the 600 dollar thing... that's not unreasonable for say just a suspension, but if you plan to wheel it medium to hard like you say, then you're going to be in for more than that.. lots of parts can get broken when you play in the rocks etc.. especially with big tires. beefed up axles, axle armor, stronger D shafts, traction aids, long travel shocks, stronger yokes, anything from crossover steering to that along with high steer tie rods.. and the arms to make it so.. it's all connected. I still have not mentioned tires &amp; wheels... it can be a money pit, but if you love doing it, it's fine, and you'll spend a lot less doing it right the first time...
However, you won't find much help at this site alone... so if you plan to go that route, plan on visiting some different forums. This was the first off road forum I ever joined, so I still like to hang around here from time to time... but it's nothing like it used to be.
Have fun, and good luck with the Blazer! [img]images/graemlins/RockOn.gif[/img]
