Door lock problems
Need information. My 68 chevy door locks don't work right.
The passenger door can only be locked once the door is shut...if you lock it before shutting the door latch/striker hits and the door will not close. Also the key will not open or lock the lock from the outside. You have to lock/unlock using the plastic button from the inside of the truck.
The driver door must be locked from outside using the key. If you lock the door while the door is open, then shut the door, it will unlock the door as the door is shut.
Any chance they are supposed to work this way?
