radio - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-16-2004, 08:20 PM
K5Blazerman77
radio
i was wondering if anybody knows if its possible to switch out a stock AM radio for a new CD player, because i took mine out of the '77 and the wiring plug-ins are different in the backs.
post #2 of (permalink) Old 11-16-2004, 10:30 PM
gregmgm
Re: radio
I did just that on my '78 GMC PU years ago. Unfortunatly, the wires will have to be cut and re-spliced onto the new CD players plug. I had to cut the opening for the new player, which I used a sawsall for. It could be easy to cut too much with that kind of saw, but it could also be done with a hacksaw blade, by hand. If you're not into doing the wire work, a local stereo shop could do it very easily.
post #3 of (permalink) Old 11-17-2004, 04:52 PM
Re: radio
Some companies make plug adapters. I think Crutchfield.com may carry them, or you might find one that works at Walmart.
c_rock is offline
post #4 of (permalink) Old 11-17-2004, 09:42 PM
K5Blazerman77
Re: radio
hey thanks for the help i'll head on down to wally world after work tomarrow
post #5 of (permalink) Old 11-17-2004, 11:30 PM
gregmgm
Re: radio
Ooops- sorry! Nobody had an adapter for my truck, so I assumed they werent available.
post #6 of (permalink) Old 11-18-2004, 01:17 PM
Re: radio
Yes, more than likely you'll have to splice in. Not too bad though since there are only about 11 wires to hook up, 8 of which will be speaker wires if you have 4 speakers in it. They are the easy ones to find since each speaker will have a solid wire and another of the same color but just with a stripe to differetiate between pos and neg. For the other ones you'll have a ground, accessory power, and constant power. As far as cutting out the dash, I used the metal sleeve that comes with the cd player and used it as the template for marking the metal dash plate and plastic dash cover. I usually use my dremmel to do the cutting.
newxjer is offline
post #7 of (permalink) Old 11-18-2004, 03:58 PM
K5Blazerman77
Re: radio
ya mine only has one speaker, in the dash and thats all so ill have to add more
post #8 of (permalink) Old 11-18-2004, 08:44 PM
Re: radio
I don't know for sure if they're available for such an old truck. Also, most new stereos have a wiring diagram on the back, or at least tell you what color wire does what. If your stereo doesn't have that, you might be able to find it on their website.
Hooking up a stereo is one of the easiest things you can do.
c_rock is offline
post #9 of (permalink) Old 11-20-2004, 05:28 PM
K5Blazerman77
Re: radio
Ok i got my CD player hooked up theres power and speakers, but the only way it plays is if the head lights are on. whats up with this.
post #10 of (permalink) Old 11-20-2004, 09:42 PM
Re: radio
When you spliced into the red power wire, you somehow spliced into the headlight wire. Get behind there and with a multimeter look for a red wire with around 12vdc on it when the ignition is set to run and acc.
blabhern is offline
