steering whoas - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-01-2004, 09:24 PM
grovey
steering whoas
hi, new to the board and need some direction. just bought a lifted 79 stepside , with a 84 nose it has a 6" spring lift. lift is not very old ,but i just bought it this way, and didn't have anything to do with the install on it. it rolls on 36/14.50/15 mickeys. but man this thing is a handfull to drive. backroads are scary. it wanders quite a bit! it only has a stock single steering stabiler on it. i've got alot to learn here about the do's and donts on these. what can i do to make this more drivable. it also has 8 lug axles. very cool truck real headturner. any input? thanks grovey
post #2 of (permalink) Old 10-01-2004, 11:52 PM
Re: steering whoas
Put the front end on jackstands, then grab a tire and start trying to move it side to side and see what happens. You're probably going to find a lot of play in the entire steering system. All of the parts are most likely still factory, so they're worn out.
c_rock is offline
post #3 of (permalink) Old 10-02-2004, 10:02 PM
grovey
Re: steering whoas
well if you add all four tires i had 51 lbs of air in them! rr was 3.5 lbs! also found and fixed front hub it had the pin smashed from being installed wrong and was screwing up the spindle threads and little piece that has the holes for the pin to lock into. drives alot better now. thanks grovey
