Re: finaley got york mounted and air tanks
thanks, iv got a bed mounted tool box im going to mount the tanks in and one of thows self coiling hose spools, ill cut a small hole in the side of the tool box with a tight gromet so just the end of the air fiting sticks out
i think i have most of the rest of the parts i still need the intake filter, falange fitings for the york, check valve, unloader, random tubes and fitings well i guess thats a lot yetya ill run metel pipe off the discharge to the oil and water separater under the hood, probley mounted to a fender or fier wall then run hose the rest of the way back
should i use pipe for like in and out on filters and the tanks or would hose be ok?, what size hose and pipe should i use? 3/8in., 1/2in.?
thanks agen
