CROSS OVER - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-31-2004, 01:47 AM Thread Starter
CROSS OVER
Have any of you guys ever tried cross over steering and if so could i get your thoughts on it.
[img]images/graemlins/givemebeer.gif[/img]
snowmancat is offline
post #2 of (permalink) Old 08-31-2004, 04:42 PM
Re: CROSS OVER
I have not. You may want to check ORU, I think that they offer a kit.
4x4mike is offline
post #3 of (permalink) Old 08-31-2004, 10:05 PM
Re: CROSS OVER
What exactly IS crossover steering and what are the benfits?
GTRider245 is offline
post #4 of (permalink) Old 09-01-2004, 12:04 AM
Re: CROSS OVER
Instead of the steering arm being linked to the drivers side spindle, it is connected to the passenger side spindle. This changes the angle/legnth of the steering arm thing, and keeps the steering from being affected by axle articulation so much. Also helps a lot to reduce bump steer.
dhcomp is offline
post #5 of (permalink) Old 09-01-2004, 12:54 AM
Re: CROSS OVER
I have it and it is the best thing to mechanical/power steering since PS... here is a pic:
post #6 of (permalink) Old 09-02-2004, 03:48 AM Thread Starter
Re: CROSS OVER
See i built mine it just took a crossover rod i turned it is a lathe and cut it down and one of the ends is welded solid and the other screws in and out for adjustment. I ended up taking to steering arms and a pitman arm and graftd one of the steering arms to the pitman arm and the other to the knuckle and measured my rod and put it all together the only problem the i ran into is when i built i did not make my pitman arm long enough and i had to go back and extend it if you are wanting to try this, with every thing set up right your steering rod should be about paralel withe the axel. All in all it helped my chevy has 14" of lift and 39x15.50x15 tire on a 15x15 rim and it steers like a dream. and if you can weld and have so extra parts around it is really cheap. Try it. [img]images/graemlins/deal.gif[/img]
post #7 of (permalink) Old 09-06-2004, 06:22 PM
Re: CROSS OVER
got any pics of your setup? 15" lift to fit 40s? I got 7" and 40s no problem, your truck must be huge.
post #8 of (permalink) Old 09-07-2004, 01:22 AM Thread Starter
Re: CROSS OVER
I don't have any pics it has not even rolled out of the shop yeat. So when it does I will send some pics your way. I still have to build drive lines and shim the tranfer. So it will roll pretty soon no big hurry I want to do every thing right.
post #9 of (permalink) Old 01-03-2005, 05:17 AM Thread Starter
Re: CROSS OVER
here are the pics sorry it took so long plans changed on it.
post #10 of (permalink) Old 01-03-2005, 05:24 AM Thread Starter
Re: CROSS OVER
and the hole thing
