-   GM Standard SFA Trucks & SUV's (https://forums.off-road.com/gm-standard-sfa-trucks-suvs/)
-   -   can 15" wheels clear on 1 ton axles (https://forums.off-road.com/gm-standard-sfa-trucks-suvs/195146-can-15%22-wheels-clear-1-ton-axles.html)
patols6 06-25-2004 12:45 PM
can 15\" wheels clear on 1 ton axles
I wanted to put 1 ton alxes on my blazer now that i snaped my front 10 bolt. But i have 15x10 wheels with new 35" rubber. I want to know if im going to be able to use the 15" wheels, or if im SOL.
b454rat 06-26-2004 09:25 AM
Re: can 15\" wheels clear on 1 ton axles
You can use 15" wheels on a Dna 60, but you will have to grind the calipers and bracket. Depending on what backspacing you use, the more or less you will have to grind. I have a set of 15x8" wheels with 4 1/4", and I had to grind quite a bit to get them to clear. But if you get a 2" b/s wheel, then you won't have to grind as much. I will try to get a pic of it, if I ever get the motovation to do anything today.. [img]images/graemlins/thud.gif[/img]
patols6 06-29-2004 12:28 PM
Im running 15x10 american racing wheels and i dont know what the back spacing is on them. What about the rear drums will they clear also?
b454rat 06-30-2004 09:37 PM
I think the rear will fit no probs.
**DONOTDELETE** 07-05-2004 05:27 PM
I have 15x10 with 3.25" BS and had to grind a bit off. I have disk brakes in the rear and had to slightly grind them too but I know guys with drums and 15s and no grinding required.
