Fouling spark plugs - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-07-2004, 01:20 PM
OLY29
Fouling spark plugs
My 77 400 motor is oil fouling the number 3 spark plug. This normally take about 3-4 weeks before is starts running on 7 cylinders. I then remove the 1 and 3 spark plug and clean number 3 and switch the plugs. What would cause this? Bad rings or a bad valve seal. The motor has just turned over 100,000 miles. It still passes the smog check every year, but I need to fix the problem.
Thanks
post #2 of (permalink) Old 06-07-2004, 10:44 PM
monsterjim
Re: Fouling spark plugs
have you done a compression check, its probably leaking by the rings though. If you can get a scope look down through the spark plug hole and see if the cylinder walls are scratched up. You're sure its oil and not just carbon build up with some gas on it. Is it hard residue or can you wipe it right off when you take it out?
post #3 of (permalink) Old 06-07-2004, 11:57 PM
Try new valve stem seals. Chevy's are bad about that. Mine were replaced at about 30,000.
Good Luck
Jim
JimC is offline
