leaf spring altering ??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-31-2004, 07:20 PM Thread Starter
Apprentice
ok, i bought the wrong leaf springs (4" superlift ez-rides)
for my sas, they have 5 leafs and have a spring rate of 560,
way to stiff for my liking, i see that tough countrys are
3 leafs and are rated at 295, can i remove 1 or 2 bottom
leafs to soften it up, or is this a bad idea, there is
some room for my truck to sag also so thats not to much of
a concern, then later on when i add a big block and winch
ill just put the leafs back in, whats your opinion on this
idea, i dont want to buy another set of springs if i can
help it, thanks,
classjoe is offline
post #2 of (permalink) Old 03-31-2004, 08:22 PM
Re: leaf spring altering ???
I removed some of mine - the PO put cement truck springs on it - at least it felt like it.
Called Leaf Spring Supply - great guys, they said you can remove the third leaf down from the top - don't remove the second leaf, it'll bend the top leaf. And you can take out the 4th down too.
Removing the short bottom one won't do much except cause breakage.
And - you can put the Teflon shims between the leaves, helps soften it.
And - you can grind a slight taper on the ends too - hard to describe - go to a spring maker and look how they do it - makes them more progressive.
Use greasable shackles too - makes a big difference as well.
Stay away from Poly bushings - too stiff and don't last long - dirt tears them up - the makers say different - but their tests are in the street - they lie about it.
RRich is offline
post #3 of (permalink) Old 03-31-2004, 08:42 PM Thread Starter
Apprentice
thanks,
classjoe is offline
post #4 of (permalink) Old 03-31-2004, 11:48 PM
Carpal \'Tunnel
wrath's Avatar
Common practice here is to take the third from top leaf out and put teflon sheet between each leaf. A 50' roll is like $20something. If you take the second leaf out you risk ruining your main leaf and if you take the bottom leaf out of a front set of springs you can end up with wrap and also ruining your springs because of stress concentrations.
Also, don't overtighten the shackle and spring eye bolts.
wrath is offline
