Re: opinions on new setup before I spend the money
Ok, first, welcome, but this is an IFS truck so this should really be in the IFS board. Looks like you're trying to get a lot of power out of that motor with bolt ons, and you're not gonna see much improvmenet from anythign but the supercharger. The spacer and airflow sensor probably won't do much.
Now for the rest, a 6" lift woudl be good, but you could easily run 35's on that. 33's will look small. If you are sticking to 33's though, you may not have to regear. If i were you though, i'd get 35's and regear appropriately. An E-locker in teh back is a good idea, but they dont' make a locker/limited slip for the front.
Shocks, get teh bilstein 5100's
Electric fans - not sure if it will be worth it, unless you need to turn off the fan for water crossings or something.
Power programmer - talk to whoever puts on the supercharger, they may not work well together.
Basically, look into more of this stuff before you spend the cash. And you should be able to do it for way less than 10k. Lift/tires should be 3500ish.
Good luck!
