ez locker & gears - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-29-2004, 01:43 PM Thread Starter
ez locker & gears
i have a 14 bolt ff rear axel, i just swaped the gov-lock out for a ez locker i tryed to use orgenal ring gear but it cant ajust all the way, thares a lot of back lash even with it fulley ajusted towrds the pinon as far as the ajusters will turn
i looked at my ring gear and theone thatwas on it when i got it thay are the same thicknes and have the same # of teath
do i need a ring gear spacer or a difrent tipe of gears? i could see that whare the ring gear mounts on the open careyer is a lot thiner then the gov-lock but what i dont get is the ring gears are the same thicknes
eney help or ideas would be gratley apresheated i need to b abel to drive this thing so i am the way it is but it makes me nerves
allso the ring gears have 42 teath and the pinon has 8 i think dose eney one know what ratio that is?
vitl2002 is offline
post #2 of (permalink) Old 02-29-2004, 10:29 PM
Re: ez locker & gears
thats a 5.25 ratio...which i dont think exists. you might want to recount
u4ia4 is offline
post #3 of (permalink) Old 03-01-2004, 12:41 AM Thread Starter
your right that dosent sound right at all, i know thares 42 on the ring but i was havung a hard time counting the pinon, it was still in the truck, ill try age when i have the cover off
dose it sound like i need a thick gear set or are thare ring gear spacers?, the open careyer is alot thiner than the gov-locker, i was even thinking about puting some washers as spacers betwen the ring gear and careyer but it just seemed to low buget
thanks for eney info that you may have
vitl2002 is offline
post #4 of (permalink) Old 03-01-2004, 01:48 AM
you'll need a thicker ring gear. they ocme in two thicknesses that i know of. the open carrier is a bit thinner and it accepts thicker gear. opposite for the gov-lock carrier. as for teh washer-spacer thing. dont do it, you'll really [bleep] up the rear end that way
u4ia4 is offline
post #5 of (permalink) Old 03-01-2004, 11:05 AM Thread Starter
thicker gears, will my stock cover still fit or will i need a difrent cover to?
i know i should replace the pinon allso bur would the ring gear work with the pinon for the thin gear?
whares s good place to order from?
if i post a pic of my ring gear with the #s on the side could some one tell me the gear ratio?
thanks for all the help
vitl2002 is offline
post #6 of (permalink) Old 03-01-2004, 12:09 PM
for the numbers on the sife, just devide the big number by the small mnumber and you'll jabve your ratioe. it'll likely be either 4.10 or 4.56.
u4ia4 is offline
post #7 of (permalink) Old 03-01-2004, 04:14 PM Thread Starter
ok the #s on the side are 2 GM 3977333 9 41 7 76
i hope that helps im trying to order gears asap
thanks agen
vitl2002 is offline
post #8 of (permalink) Old 03-01-2004, 04:55 PM
41/9 is 4.56
u4ia4 is offline
post #9 of (permalink) Old 03-01-2004, 10:27 PM Thread Starter
cool so i just need 4.56 thick gears and a install kit
will my stock diff. covr still fit?
thanks for the help you relley saved me a lot of head akes
vitl2002 is offline
post #10 of (permalink) Old 03-02-2004, 02:30 AM
yes covr should fit. if it doesnt, beat the hell out of it with a hammer
u4ia4 is offline
