454 oiling - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-11-2004, 02:13 AM Thread Starter
454 oiling
ok i know this is stupid but i have a 454 fron a 82 to 84 suberben in my truck and i was just wondering if 3 galons of oil sounds right for it?
its been completley rebilt cam pistons bored intake exost but i dident bild it so i dont know if the oil pan is stock, its a steal pan and it has a after market dipstick that was marked for whare the oil should be
it just seems like a lot of oil to me, iv been running it for about 2 years like that and it has seemed fine, has a rear main leak but no big deal
the other thing is it was swaped in to a 84 chevey desel and at hot low idel the oil presher is arownd 40 psi it idels low arownd 500 to 700 rpm cus of the cam and high compreshon pistons then when driving it gos up to about 80 psi, is this normel? could it be a difrent oil presher sensor or gage giving me wrong readings from the desel truck or thay may have put a high flow oil punp in?
eney help would be gratley apresheated
thanks
vitl2002 is offline
post #2 of (permalink) Old 02-11-2004, 10:52 AM
Re: 454 oiling
454 usually takes 7 quarts. I would try that and then check the level. Have you put on a larger pan? If so get the cap. of that.
4x4mike is offline
post #3 of (permalink) Old 02-11-2004, 11:39 AM
Re: 454 oiling
if the oil pan from the diesel was used then yes it sounds about right. diesels take much more oul that gasoline engines. if it is teh stock oil pan then 7 quarts is about right.
as for the oil p[ressure. yes, when the engine is hot, the pressure will be lower. and when you accelerate the pressure will build up. mine is about 30psi idle and 65psi driving.
u4ia4 is offline
post #4 of (permalink) Old 02-13-2004, 12:11 AM Thread Starter
Re: 454 oiling
cool thanks for the help, i never thought of them mabey puting the desel oil pan on it but that would make sence
thanks agen
vitl2002 is offline
post #5 of (permalink) Old 02-16-2004, 09:33 AM
lebowski
Re: 454 oiling
Alcohol Engineer,
Will the diesel oil pan swap onto a 454? I've never heard of this, so just wondering is this doable. I'm asking because I have a 454 in my Suburban also.
Thanks
post #6 of (permalink) Old 02-16-2004, 04:56 PM
Re: 454 oiling
i dont know if itsw possible or not. the best way to gfind out is to PM a guy on the IFS board named krayzie. he has GM dealer pictures for just about everything. one could match up the bolt holes and see if its do-able. i dont know from any type of experience though.
u4ia4 is offline
