front driveshaft help please - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-08-2004, 06:03 PM
vlucdog
i'm looking at buying a '89' gmc jimmy and it has a bad slip spline yoke on the front drive shaft. where do i go to find one. i've checked all the site sponsers. mabye i'm calling this part by the wrong name. this must be a common problem because i looked at a "86" yesterday with the same problem, my best guess is that this is also found on half ton pickups
post #2 of (permalink) Old 02-08-2004, 06:08 PM
Re: front driveshaft help please
Here's links to a couple of places:
http://www.thrashdriveshaft.com/4_wd...ET%20AND%20GMC
http://www.iedls.com/critical.html
I've done business with Inland Empire Driveline in the past, they do good work.
You can also comb the junkyards for what you need.
c_rock is offline
post #3 of (permalink) Old 02-08-2004, 06:15 PM
vlucdog
c rock; thank you for the reply .
bill
post #4 of (permalink) Old 02-08-2004, 07:08 PM
I'd think any local driveshaft shop should be able to help you out....
What makes you say its "bad"?
dhcomp is offline
post #5 of (permalink) Old 02-09-2004, 05:17 PM
vlucdog
well im going to drive this jimmy tommorrow. i also drove one saturday. the sat. jimmy had either the splines worn or the female part internal splines wore out , because when power braking on ice the rear tires spun and the shaft from the transfer case to the slip joint turned but the front half didnt. the jimmy im driving 02/10/04 has quite a bit of play at the slip joint. i think i just need to be ready to fix this . also i'm going to be looking for a boot to cover the slip joint.
thank you for
your replys
also i forgot there is a local shop that could fix it
bill
