tiers lift and diff - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-24-2004, 02:11 AM Thread Starter
tiers lift and diff
i just ordered some bias 36 tsl swampers, how are theys ont the street?
how do you balance them? golf balls, led shot, bbs?
i ordered a 6 in. lift with rear springs from rough countrey its my first lift and im wodering about drive shaft angels and langths, its a daley driver and no 4x4 shops hear
and last is i have a 14 blot ff with a gov lock it had a open in it and with the cover off and tiers off the grownd you could turn one tier by hand and the other would not turn but the diff would click and you could watch the side gears overrunning a noched pice that meshed with ther teth i opend it up and thare wer no markings to make me think it was eneything after market
i put the open careyer on the flowr and heald it in place and had a freend put an axel shaft in and try to spin it the whole careyer wanted to turn, when i tryed the same thing with the gov lock just the axel would turn not the careyer
is it relley just an open?
id apresheate neey help i could get, thanks
vitl2002 is offline
post #2 of (permalink) Old 01-24-2004, 11:46 AM
Re: tiers lift and diff
What truck is this going on? Driveline angles and vibration problems have alot to do with wheelbase legnth. Besides that, someone should be able to describe what the gov lock looks like and what the open carrier looks like. It is my understanding that a gov lock needs 1 axle to spin a certain number of times more than teh other before it partially locks them together, so it would be hard to get it to ingage when not driving the truck . Good luck!
dhcomp is offline
post #3 of (permalink) Old 01-24-2004, 02:55 PM
gottagofast's Avatar
a govloc has a govener which is a couple weights on a shaht that spread when they spin to engage the locker .... when one wheel spins faster than the other it causes the govener shaft to spin .. when the difference is enough the locker engages. this is why govlocs tend to break when you hot rod and spin alot on the street as the tire is already spinning and the locker has to "catch" it and stop it from spinning or break the other tire loose from the pavement instantly and that puts alot of pressure on stuff
It sounds like what you have is an easy locker of some kind. in your "turn one wheel" test you didn't say whether the diff was in the truck or not. when you turn one wheel the other wheel OR the driveshaft will turn with an open diff ..... the other wheel AND the driveshaft will turn with possi ...... with an easy locker it depends on the direction that the d-shaft is torqued ie if the d-shaft is trying to turn the wheels forward and one wheel is resisting the other wheel can freewheel forward and overrun the diff usually making a clicking sound.
gottagofast is offline
post #4 of (permalink) Old 01-24-2004, 11:43 PM Thread Starter
thanks for the help gies, i have the gov-lock in my truck now, this other careyer is an open it has the 4 side gears and all that
when i whas turnig the tiers by hand it was in the axel in the truck with bowth tiers off the grownd and the drive shaft off the one tier would spin the other dident just the clicking noise
then i took the careyer out set it on its side on the floor and held on to it i had my freend put a axel shaft in and try to turn the axel and the whole careyer wanted to turn when i tryed to do this with the gov-lock just the axel would turn
hope this helps, i took some pics but if ther no good ill post some more when i can take it apart agen
thank you for your help
vitl2002 is offline
post #5 of (permalink) Old 01-24-2004, 11:46 PM Thread Starter
hears another pic
vitl2002 is offline
post #6 of (permalink) Old 01-25-2004, 03:55 AM
That's an easy locker!
post #7 of (permalink) Old 01-25-2004, 08:31 AM
I have the govlok in my 14ff and it doesn't look like that. It is a 3 pin style and no visable side gears. Looks like an open carrier.
b454rat is offline
post #8 of (permalink) Old 01-25-2004, 10:45 PM Thread Starter
sweet an easy locker, that should be nice to have the gov lock i have works ok but i just dont trust it id hate to have that brake whale im out
who makes the easy locker?
for the lift qwesgen its a 84 3/4 4wd 454 np208 sm465 2 door long bed with 56 in. rear springs ans a slpi yoke rear drive shaft dana 44 front and 14 bolt ff rear
hope that helps, i should have posted that in the first place but dident even think about it
hope the bise ply tsl tiers arent to bad on the street iv heard evreything from ther tarebel to ther not that bad at all exept for the noise and that dosent bother me, just wondering about balancing them
36/12.5R16.5 think mabey 4 or 5 galf balls per tier?
thanks for all your help gies, this has saved me some head aces
vitl2002 is offline
post #9 of (permalink) Old 01-26-2004, 03:54 AM
I personally wouldn't put anything in my tires but air but there are those that put all kinds of stuff in them...... balance them just like any other tire ..... on a tire balancer .... if you want auto balance get centramatics
There are several companies that make similar lockers all they do is replace the side and spider gears in an open diff. Notice in the pic that there are no spiders only sides and the plates they ratchet on
