? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-16-2003, 02:27 AM
nicotine
is it a good idea or a bad idea to use aftermarket shackles with a shackle flip in the rear what are the pros and cons.
post #2 of (permalink) Old 11-16-2003, 03:46 AM
Re: ?
You mean use a longer aftermarket shackle to give more lift? As long as you do it within reason it should be ok. Just watch your pinion angle since it will point up more the longer the shackle you use. And make sure the shackle is sturdy enough to take the additional side loads.
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
willyswanter is offline
post #3 of (permalink) Old 11-21-2003, 08:35 AM
A1980GMC's Avatar
Re: ?
You could probably use a shim to help correct the pinion. I mean use the shim in the opposite way to lower your pinion.
Jason what do you think of that idea? I think I should have installed my 3" block backwards. My pinion is slightly too high.
Laters, Ryan
A1980GMC is offline
post #4 of (permalink) Old 11-21-2003, 11:58 AM
Re: ?
I don't like shimes. Every shim I have ever installed as split in half and fallen out within weeks of installing it... Both alluminum and steel... It got easier to just replace the rear spring pads on the axle then replacing shims once a month.
