motor bolting to tranie - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 11-12-2003, 09:22 PM
i have a 1983 chevy k20 4x4 and i let someone use it for a day to move somethings and when i get it back it is knocking so i check the oil and there is no oil but i have a 350 that came out of and olds cutlull i need to know if it will bolt to my tranny before i take it out of my car and try to put it in my truck if anyone knows please email me at [email protected] i would be very greatful
thank you chevy45x4 [img]images/graemlins/AR15firing.gif[/img] [img]images/graemlins/AR15firing.gif[/img]
post #2 of (permalink) Old 11-12-2003, 11:39 PM
Re: motor bolting to tranie
what engen and trans. it in it?
vitl2002 is offline
post #3 of (permalink) Old 11-13-2003, 12:23 AM
Not sure if i understand your question, but if you are putting the cutlass tranny in the truck, be careful. Not sure about that particular tranny, but most trannys in trucks, even if the same model, were built with stronger cases, etc...
dhcomp is offline
post #4 of (permalink) Old 11-13-2003, 07:49 AM
<font face="Comic Sans MS">If you're asking whether the engine from the Olds will bolt up to the transmission that's already in the truck, the answer is no... Different bolt pattern between the buick olds pontiac engines, and regular chevy/gmc engines if I recall correctly...
If you're asking whether you can bolt the engine and transmission out of the Olds into the truck, I would say no, because you'd have to find a divorced mount transfer case, and stuff like crossmembers...
Basically either way it won't work, or at least not well at all... Might be able to find a decent replacement in a parts yard out of a lower mileage rollover, or something... Worth a shot anyhow... </font>
The_Sandman_454 is offline
post #5 of (permalink) Old 11-25-2003, 07:06 PM
desertrat67's Avatar
the cadcompany or MTS sells an adapter plate to mate and Old, Buick, Pontiac, Cadillac engine to a chevy tranny. about $120.
desertrat67 is offline
post #6 of (permalink) Old 11-25-2003, 09:37 PM
gottagofast's Avatar
You CAN put the olds trans in the truck is they are both the same ie th350, but, you will have to put the 4x4 output shaft in the olds trans which requires a complete teardown of both trannys prob cost $100 - $200 min at a trans shop.
I put a caddy 472 and olds th350 in a k-20 but I swapped the shafts myself. ...... mmmmmmmm pizza and atf ..... can't beat the taste!!
gottagofast is offline
post #7 of (permalink) Old 11-27-2003, 08:28 AM
I'm with Sandman here. The Olds engine and tranny have different bolt patterns than Chevy. It's the Buick-Olds-Pontiac (BOP) thing.
c_rock is offline
