4" lift. Will I have to cut for 35's? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-13-2002, 06:51 PM
joeybcdt
4\" lift. Will I have to cut for 35\'s?
'83 Jimmy. I 1st thought I was gonna do a 2.5" lift and run 33's. Now I'm leaning toward a 4" lift and running 35's. With 35's, will I have to cut the fenders? Will 35's put too much strain on corp 10 bolts or other parts? I've never run anything over 33's. I'm used to running a Jeep.
There are no rocks around here. Just lots of mud and sand. Every 4 or 5 years I go to West Texas...some rocks and mountains.
Thanks,
Joey
post #2 of (permalink) Old 10-13-2002, 07:52 PM
Re: 4\" lift. Will I have to cut for 35\'s?
yes you will have to do minor triming on the front. that should be all you have to do. the axles are a nuther story. I have Know people who have no problems and more who have had problems alot depens on how much you like the right pedal.. good luck
chevyman_400 is offline
post #3 of (permalink) Old 10-13-2002, 09:30 PM
87sm465np208
yea most people have said you need to do mods to your truck to fit 33's in them wheel wells, i have 33x12.50s, they fit fine, but are all that will do with the way it sits stock. i could imagine you might have to cut for 35's with 4 in of lift if you flex it, ive flexed mine didnt rub, i dont know i would put the tires on the truck and do a visual check before you cut especially if you have good quater panels.
post #4 of (permalink) Old 10-13-2002, 09:54 PM
Carpal \'Tunnel
wrath's Avatar
33s on 15x8s will fit with 4" of backspacing without a lift.
I had a post earlier this week about wheel width:
http://bbs.off-road.com/ubbthreads/s...o=&fpart=1
35s will rub with 4" of lift when stuffing the tire. Tim has nicely polished inner wheelwells and cut fenders with 4" of lift.
35s will be alright if you don't beat on it. The axle will actually last longer if you have a crappy ratio like 3.08 or 2.73 since with a large pinion gear you're less likely to have your ring gear spit teeth.
wrath is offline
post #5 of (permalink) Old 10-13-2002, 10:47 PM
87sm465np208
hmm didnt know about the 33" tire fitment thing, i will have to check out to see how wide my rims are, very insteresting wrath, by the way, how did you work out your own tire fitment problem?
post #6 of (permalink) Old 10-14-2002, 05:25 AM
Carpal \'Tunnel
wrath's Avatar
A pair of channel locks, a dremel tool, and a hammer. She's still a tight fit. If I have the wheels turned to just the right spot, stomp on the brakes, and hit a bump she'll rub. I didn't have any rubbing offroad though.
wrath is offline
post #7 of (permalink) Old 10-14-2002, 01:40 PM
I'm guessing you will. My 33's rub with my 3" lift when its really flexed out, but that was when the tires were new. Now they are worn down enough that they are probably good.
90K5 is offline
post #8 of (permalink) Old 10-14-2002, 02:37 PM
I know someone who has a 4" superlift on his k5 blazer. He is running 35's on 15x10 ar 767 wheels. He didnt have to trim.
Yukon97 is offline
post #9 of (permalink) Old 10-14-2002, 02:52 PM
joeybcdt
Wrath:
Are you saying that if I use 15 X 8 wheels with a 4" offset that I won't have to use any lift at all? If so, that sounds good to me.
Joey
post #10 of (permalink) Old 10-14-2002, 03:10 PM
87sm465np208
yep i guess thats the ticket
