An elusive engine problem !! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-08-2002, 10:46 PM
sayl4u
Every so often my truck will stumble/hesitate like it has no power to the coil,It lasts about a minute or so intermitently and then it clears up.I have replaced the coil and the ignition modual checked the connections and wiring..
post #2 of (permalink) Old 10-08-2002, 10:51 PM
Re: An elusive engine problem !!
Fuel pump?
Is this condition under throttle? off idle?? warm motor/cold motor??
beaterchevy is offline
post #3 of (permalink) Old 10-08-2002, 10:52 PM
sounds like something that happened to me...
What it was in my case was damaged distributor cap. If it's not that I would be apt to check the rotor. If you already checked all the connections though *shrug* I dunno, someone else will probably know more though.
good luck
post #4 of (permalink) Old 10-08-2002, 11:02 PM
sayl4u
Under throttle,warm engine.ive checked the cap and rotor and replaced the fuel pump and it did it with the old carb also!79 400,th350,np203converted..
post #5 of (permalink) Old 10-09-2002, 08:54 AM
Do you have after market wires, that are low resistance?
post #6 of (permalink) Old 10-09-2002, 09:22 AM
sounds like you replaced the fuel pump but did you replace the fuel filter too? I had a glogged filter that would do that slow to the point the truck wouldn't run anymore.
post #7 of (permalink) Old 10-09-2002, 02:20 PM
Is the ignition timing good? I had similar problems with my truck. I had a bad distributor cap. I replaced it and it seemed to help a lot. It still didn't seem powerful enough. I took off my timing cover and was missing 10 teeth off one of the gears and i could fit my finger between the gear and the chain. Have you tested to make sure you are getting plenty of power to the coil or off of the distributor?
post #8 of (permalink) Old 10-09-2002, 05:57 PM
I have this proble in my shop before!!! what you wight do is replace the pick up coil,. tou have to pull the dis. compleatly out and compleatly a part to do this
have fun [img]images/graemlins/smile.gif[/img]
chevyman_400 is offline
